Going to the track 2wd or 4wd?
Old 01-29-2008, 06:24 PM
BigJohnston's Avatar
What is the best way to get good numbers at the track? I can either feather the pedal in 2wd until I get going and let it rip or do a boosted launch in 4wd.
What do you guys think is best? Thanks, Tom J.
Old 01-29-2008, 06:56 PM
Big Horn's Avatar
it will definatly be faster to build a little boost and hit it in 4wd. with your goerend parts you should be able to handle some 15psi launches.
Old 01-29-2008, 07:08 PM
JRD
JRD's Avatar
Launch in 4Hi then after launching kick it up into 2Hi. Good luck and keep us posted
Old 01-29-2008, 07:31 PM
RamWheelsBy4's Avatar
I use 4hi 4wd and 15-20psi launches. Just leave it in 4hi until you are slowing down, then shift to 2hi before you turn off. It wont release anyway until you slow down.
Try it both ways and I think you will wind up in 4hi. Without drag radials and traction bars I had no way to hook up quick enough to run a good time in 2wd.
Old 01-29-2008, 09:15 PM
Racing4funn's Avatar
Yea thats what Im thinking.. I wouldnt want to make that shift under power
Old 01-29-2008, 09:18 PM
Billm2004's Avatar
4WD and 15 PSI. in 2wd you are just going to lose too much time off the line to make it up
93Fury
03-31-2010 01:33 PM
Jordan5687
02-18-2009 02:48 PM
VikingDiesel
Competition / Pulls / OffRoad
12-29-2006 07:17 PM
95black2615
12-20-2006 06:37 PM
1320
05-06-2003 06:30 PM
Quick Reply: Going to the track 2wd or 4wd?
