Going on a Test drive
Old 05-13-2009, 11:07 AM
johnnyboy_10138's Avatar
I am going to go test drive an 04 quad cab thats been lifted. What are a few things i should look for to make sure it is a good buy?
Old 05-13-2009, 11:10 AM
pdogg's Avatar
1. the price
Old 05-13-2009, 11:12 AM
haha 14800
Old 05-13-2009, 11:20 AM
MOAGGIE's Avatar
Look over the lift, check u-joints, tire wear, leaks, see if it looks like nothing has been cracked or welded, in additional to all of the other normal Dodge/Cummins gremlins that could be there. Good luck with the test drive.
Old 05-13-2009, 05:18 PM
Thanks guys. Hopefully it will check out and I will be able to post some new pics of my new truck soon.
Old 05-14-2009, 03:40 PM
Just got back from a test drive of the truck. The truck is great. Very clean, leather is in great condition. Has a slight rear main seal leak. Dodge mechanic said it looks like it is a slow leak, barely drips. How bad is this? Since I am getting it for such a good price, I am not too worried about it, unless i should be... Post more info when i have it
Old 05-16-2009, 08:27 AM
TonyB's Avatar
This is the first I've heard of a rear main seal leaking. How many miles on the truck? An '04 with <100k miles, I'd have the warranty transferred and make dodge fix it.
Other than that, it sounds like a decent deal.
Tony
Old 05-16-2009, 08:52 AM
mikmaze's Avatar
what did the valve cover plate say? 305 hp, or 325 hp ? will make a big difference in how you go forward, and what kind of mpg you will see.
Old 05-20-2009, 03:46 PM
Finally got the truck. Here are some pics.
So I was down and miami with the truck and went out to drive home... and I had a flat. This was the culprit
The lines running away from the crack is the fix a flat that came spewing out of it when i put it in. After driving 6 hours home on the stock spare, I went out and bought a full sized spar to have with me.
Old 05-20-2009, 05:33 PM
TonyB's Avatar
Congrats!
Nice looking truck!
Tony
Old 05-20-2009, 06:23 PM
Thanks, it finally stopped raining, well for like 5 minutes So i ran out and took some pictures.
wish i could get some qualities pics.
Old 05-20-2009, 09:58 PM
04DEEZELRAM's Avatar
My buddy has been throught 2 wheels with the same cracks in them
Old 05-20-2009, 10:48 PM
Arrow
Have they been dick Cepek wheels by chance?
Old 05-21-2009, 01:29 PM
tool's Avatar
Congratulations on your new purchase, very nice truck.
IS it an auto or a manual?
If it's a manual you'll want to get that rear main leak fixed ASAP, it will soak your clutch and ruin it.
Truck looks great!
Have fun.
Old 05-21-2009, 03:20 PM
Rednecktastic's Avatar
Are you sure its the rear main because there is a vent tube that runs down there right?
Quick Reply: Going on a Test drive
