Give me some details about pop testing please
Old 04-11-2006, 11:36 PM
GlennRMK's Avatar
Still searching around on injectors.
I'm debating getting a set Jammer II tips or looking for a used set of Machs.
If I get just the tips, as opposed to the whole Jammer II injector from City Diesel, I need to pop test. Or if I get used injectors, I would like to pop test them as well.
My buddy works at a mine as a diesel mechanic and said he can pop test stuff for me for free.
Can any pop tester check Cummins injectors? He does a lot of work on Caterpillar stuff but I'm not sure what kind of machinery would have Cummins engines. Does he need a special tester/adapter?
I'm assuming if he can pop test, he can adjust them if they are off?
I notice City diesel says they clean, pop test and balance. Is balancing just making sure the pop off pressures are the same? What do you need to do to clean them?
I have a spare set of ETC/SO injectors that the tips could be installed on. Only have 85k miles on them. These should be fine for the tips, correct?
Local diesel shop wants $35 a piece to adjust the pop off pressures. So, if I can get the City Diesel ones, it would be cheaper. Unless my buddy can do it. But, I would still like to pop test if I get a used set of injectors.
Any info is appreciated.
Old 04-12-2006, 07:30 AM
jasonjones's Avatar
Sure it can, with the proper adapter. All Dodge dealers received one of these adapters as part of the required tools for CTD trucks. The Miller/SPX tool number is 8301 - Adapter, Fuel Injector. Maybe your local Dodge dealer will let you borrow or rent it from them. I'm sure that 99% of them don't even use it. It would have come packaged in the 1998.5 24V CTD tool kit. I hope this helps!
Old 04-12-2006, 08:24 AM
plow's Avatar
I tried to get some tested at my local dealer and they didn't have the adapter, Heck it took them 15 min. just to find the tester then told me they coudn't do it. If your close to a john deere shop they can do it, they can usually do it while there still in the truck.
Old 04-12-2006, 09:23 AM
JDGnut's Avatar
Your JD dealer won't have the holder for the 24V injectors... No problems with the 12V injectors...
Any injection shop should be able to tested them.. some will check them for free.. and only charge you if they need to be adjusted...
Bryan
CumminsRedneck
01-11-2010 11:26 AM
speedster1858
01-10-2008 04:57 AM
dieselJon
11-21-2007 05:53 PM
973604x4
09-04-2007 08:18 PM
Mglass1045
06-05-2006 09:03 PM
Quick Reply: Give me some details about pop testing please
