Getrag questions?
Getrag questions?
Can anyone have a Getrag service manual in PDF that they can pm me? Im rebuilding one, but having tough time pulling the countershaft. What is a good source for shims in the tailhousing.
On the front of the transmission, down low on the front of the case, is a rubber covered steel plug. Take a punch and punch out the middle, and then pry the plug out of it. Remove the snaprings. The counter shaft drives out the front with a long large punch and a 8# hammer. Once you remove the shaft, the cluster gear pulls right out.
You can get shims through Zumbrota Bearing and Gear and a few others. NV4500 shims will work for the main shaft, but are too big for the counter shaft. If you cant find any, PM me; I have resources.
PM JLEONARD for the getrag PDF file.
Daniel
Daniel
Thanks everyone. Found a service manual online, and standard transmission is 30 minutes from me. For the countershaft, we got the plug out, and finally figured out to pull the shaft. Thanks again, Randy.
justagoodolboy
03-20-2007 07:33 PM
1stGenBikeHauler
10-29-2002 11:48 PM
