Get a real water temp gauge!!!!
Old 06-28-2007, 08:34 PM
rbrettctd's Avatar
Talking Get a real water temp gauge!!!!
After replacing nearly every cooling system part, I finally installed an Isspro water temp (actually tranny temp) gauge. Isspro reading at 75: 185* Factory gauge reading at 75: H, bout 2/3 of the way between the middle mark and the Hot mark. In other words, get a aftermarket gauge before rotting the radiator, replacing the thermostat twice, etc...I was not using my head...
Old 06-28-2007, 10:46 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
Yes. It helps to know what things really are. The factory gauges are made without numbers because then they don't have the hassel of actually making them read correctly. As long as it reads somewhere between min and max is OK!
I feel the same way about my oil pressure. The factory gauge just says, "yes, you have some."
Edwin
Old 06-29-2007, 04:29 PM
Thankfully, "some" is usually all the Cummins needs.
mar67655
03-21-2009 05:35 AM
rbrettctd
06-16-2007 10:10 PM
drschumm
01-20-2007 10:27 AM
Tuckerdee
07-26-2006 04:26 PM
Quick Reply: Get a real water temp gauge!!!!
