how to get quad through firewall?
Old 02-16-2008, 07:17 AM
DuaneWKKC's Avatar
Got my xzt+ last night after dark, got up early today to install but dont really want to drill through the firewall, if I don't have to. So how did you guys run your harness through the firewall.
Thanks,
DuaneW.
Old 02-16-2008, 07:43 AM
J Lent's Avatar
Look at the firewall, right below the brake hydro unit there is a rubber plug where all the factory wires come through. If it doesn't fit through the hole, put a small cut in the boot & push it through.
Old 02-16-2008, 07:44 AM
fordkiller43's Avatar
JLent is all over it! Hes right on the nail. Good luck
Old 02-16-2008, 07:47 AM
DuaneWKKC's Avatar
I see that now, will try just looks very full.
Thanks.
DuaneW.
Old 02-16-2008, 07:52 AM
Youre best bet is to pull the rubber grommet off and cut a bigger hole in it.
Old 02-16-2008, 08:24 AM
DuaneWKKC's Avatar
Got it installed.. now for a test.
Going to do a search on switch positions, looks like center is off? but then you have a choice of towards red or black. Anybody know which one for mpg or hp?
DuaneW.
Old 02-16-2008, 08:32 AM
Awesome man! Cant help ya with the other stuff tho
Old 02-16-2008, 10:11 AM
GFB
GFB's Avatar
DuaneW.
Center is timing setting. One side will be off and the other will be timing/fuel. Mine has white, red, and green wires with white being off and green being timing/fuel.
Regarding the firewall boot--I have all kinds of stuff ran through there and there's still room for a lot more. It's like a 4" hole if you take the boot out.
Old 02-16-2008, 02:44 PM
DuaneWKKC's Avatar
Just back from a 100 mile test drive ( ok, i'm lying, watched the end of the race before getting back on here ), looks like the mpg's are up a little, have to keep watching but I have 100+ miles and needle still touching the full mark on the gauge. Have not done good power test yet but under some moderate acceleration you can REALLY feel the kick in the but when you toggle to the power setting. So far, I'm impressed and will now have to learn the different tunes on the update page. Thanks for the quick responses this am, helped a bunch.
DuaneW.
michael_b8
08-31-2007 07:46 PM
johnontheroad
06-13-2007 09:50 AM
carl20320
03-07-2007 05:43 PM
clarson80
02-01-2007 04:27 PM
hipsi
05-01-2005 09:31 AM
Quick Reply: how to get quad through firewall?
