PDA
View Full Version : Where to get headlight relay harness at?
95black2615
10-13-2007, 08:02 PM
I'd like to buy one, but the summit kit that I see listed in the archives has been discontinued.
Summit lists a substitute replacement, but I am unsure if it would work. They list a 9004 bulb harness and a 9007 bulb harness.
I don't have sport headlights, just factory style.
oldblues
10-13-2007, 10:20 PM
hi
i got mine at summit racing .com !
95black2615
10-14-2007, 08:52 AM
hi
If it is summit part number: SUM-890030 you cannot get it anymore. It's not available. That's why I'm posting this.
b4wheeler
10-14-2007, 10:53 AM
I think you have the number wrong.....
It is SUM-890300
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D890300&N=700+115&autoview=sku
CarlJensen
10-15-2007, 09:53 AM
The 95 uses a 9004 bulb. I have the harness installed with a 9004+50 bulb in each side. Also polished out the plastic lens material on both sides to get rid of yellowing and scratches. Helps a lot and takes load off the stock switch.
95black2615
10-15-2007, 05:38 PM
I have new one piece clear headlights. It helps a lot.
Do you happen to have the part number for the harness you bought?
JPR Ram
10-15-2007, 05:42 PM
Try www.lmctruck.com I know they have them.
JPR Ram
10-15-2007, 05:55 PM
http://www.lmctruck.com/icatalog/de/t.asp?page=20
Here's the actual link for what you are looking for.
CarlJensen
10-15-2007, 06:48 PM
Yep, that one from LMC is the same one I have installed. Easy install and takes all the load off the lousy switch that Dodge used. Stops it from burning up. Then I used 2000 grit paper and medium rubbing compound to take the yellowed layer off the light covers. Polished out with compound and a wool bonnet. Makes a lot of difference!
95black2615
10-16-2007, 06:47 AM
That's exactly what I am looking for. Just ordered it. Thanks![guitar]
oldblues
10-16-2007, 10:28 PM
hi
summit p.n. amc-509104 $ 40.69 is what i bought and they are in stock ready for shipment , for 9004 style bulb .
rolling18
12-14-2007, 03:14 PM
i just got my kit that you guys recommended from LMC..
what a wierd company!! they sent it in a HUGE box about 2feet by, 6" by 1ft!!
and i could barley read the direction on the back of the box, misspelled words, very wrong grammar, not what i would expect from a business..
did you have anything come up during installation that was not listed?
thanks!
Valv
12-14-2007, 03:21 PM
thanks!
Yes box was huge, and full of peanuts, instructions are direct translation from China, of course you cannot expec much, I didn't even look at it, it' was very simple to install.
Only issue I had harness was too short for what I liked, I added 10" of wires.
Valv
12-14-2007, 03:23 PM
what a weird company!! they sent it in a HUGE box about 2feet by, 6" by 1ft!!
thanks!
Yes box was huge, and full of peanuts, instructions are direct translation from China, of course you cannot expect much, I didn't even look at it, it' was very simple to install.
qwest
12-14-2007, 03:58 PM
I think LMC is a Re-seller, don't stock anything, Just My Guess.
I tried to order over internet, did't work..
Called, finially got someone who seemed smart, ordered part,
Than they told me 7-9 days process time plus shipping time ...' Forgetaboutit'
I'm sure it's me, but I think I'll order from Summit...
Only problem, I'll wind up buying other stuff to fill the box....
??? Maybe the summit Harness is longer,
but probably same part with a higher price tag... oh well, that's life...
rolling18
12-14-2007, 08:35 PM
well i just finished installing it and it works!!
so im happy as well as my headlight switch is too hehe
anyway now ill see if i can tap ijnto that relayed harness to power my fogs..[duhhh]
95black2615
12-15-2007, 05:16 PM
Yep, I installed mine about a month ago.
I actually was bright lighted by someone last weekend
blackimpala
12-16-2007, 09:27 AM
Bought my truck about three years ago. Built my relay harness and had it in a week after I got the truck. Nice thing about it is you can use any size wire you want, not limited to what "they" want you to use. It has worked flawlessly. I would do it again on any thing I own.
haloman
12-16-2007, 05:49 PM
I am going to try this but use the parking light wire to activate the relay so I dont have any more issues with the highs sticking on with the lows/fogs with the LMC harness.
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/foglites.htm
Tractor Truck
12-16-2007, 08:05 PM
Haloman,
I am looking to get the harness from lmc for my truck. I noticed that you had a problem with your high beams staying on. Is this a common problem for this harness. I have factory fog lights so I am not sure if I will have the same problem. I would like to know if I will have a problem before I order the harness.
dssimecek
12-16-2007, 10:08 PM
Suvlights also has the harness with relays and also can get bright bulbs from them. I have not got mine yet.
Here is a linkhttp://www.suvlights.com/index.php?cPath=59&osCsid=55507398b90da7c171da16bed77f8633
haloman
12-17-2007, 08:04 AM
Haloman,
I think this is a common problem. But with all my other upgrades, I don't use my high beams anymore. I am going to build a harness similar to what I posted above. (have all the parts just no time ATM). That should fix it by using the marker light to trigger the relay and take the fog light load off the headlight switch.
rolling18
03-30-2008, 04:08 PM
well UPDATE!!!
my low beam relay died!!! and i cant find another on the internet!!!
anyone know where to get these?? (besides calling LMC and ordering again)
NONE of the auto part stores even heard or seen them b4..
i dont want to have to mail order relays every time one goes out..
i would advise against this kit due to REPLACEMENT relay availability:(
haloman
03-30-2008, 04:14 PM
Radioshack should have the relay.
rolling18
03-30-2008, 04:27 PM
thanks for fast responce!! but unfortunatly they dont.
i found the company web page and it was listed there but no info how to order or where to order.. very poor web page
[coffee]
haloman
03-30-2008, 04:33 PM
really? Mine here in town had them. You have the harness from lmctruck.com right? A standard bosch relay should work.
caper
03-30-2008, 04:36 PM
I changed out my relays on the LMC harness to hella relays and bases for easyer replacement. Any one know where ya can find the 2 headlight sockets and the one socket that you plug into the factory harness so one can make their own harness , I can't find them anywhere.
rolling18
03-30-2008, 04:38 PM
yes i have the LMC kit... i cant find bosch relays arround here either..
autozone, schucks/ checker. baxter radio shack ect. auto parts none have bosch
mabey you have a part number??? i will research bosch
the relay that came with it is called "SHORI" has 4 prongs all horizontal in a 2x2 patern female socket...
haloman
I found some sockets at walamart, should be able to get them at autozone or similiar.
haloman
03-30-2008, 04:43 PM
Not trying to be smart, have you tried calling some of these place?
http://www.google.com/search?hl=en&safe=off&q=portland%2C+or+electronic+parts
http://www.superpages.com/yellowpages/C-Electronic+Components+Retail/S-OR/T-Portland/
rolling18
03-30-2008, 05:12 PM
its ok i am thankfull for the help!!
if im luckey enough to find a place open on a sunday afternoon, they want to know what kind of bosch relay and i try to describe the socket i need and they
always want to see it.
radio shacks web page has no bosch relays at all that i could find..
i cant find the exact style i need on bosches web page either..
what a pain! [duhhh][duhhh][duhhh]
rolling18
04-03-2008, 12:54 AM
well i called LMC and they are sending me another wiring kit for free under warranty, but they still could not tell me where to get these relays for future burnouts[duhhh]
