Where to get a gasket
Old 09-19-2005, 06:42 PM
engcogod's Avatar
When I first got my truck & installed gauges I did everything safe (paranoid ) lol and seperated the turbo from the manifold to tap the manifold. Well I took off the Turbo Oil Drain Line and when I was finished put everything back together... Every now and then I check under the hood just to make sure everything looks good & There is some oil seepage running down that tube. Both bolts are tight so I'm figuring I disturbed the gasket & now I would like to put a new one on...
Does anyone know the part number & where I can obtain one?
Old 09-19-2005, 10:23 PM
bmoeller's Avatar
If I could find the reciept, I'd give you a P/N.
Call a Cummins shop or distributor, or a turbo shop.
http://www.cummins.com/na/pages/en/d...r.cfm?state=pa
Some of the vendors here, may have them as well.
ted_pulliam
07-16-2009 11:33 AM
jmccart
07-31-2008 11:46 PM
wildchild97
09-25-2007 02:44 PM
fearthedeere
02-09-2006 06:38 PM
Quick Reply: Where to get a gasket
