how to get 450hp
Old 07-02-2010, 09:02 PM
silverking90's Avatar
how to get 450hp
I got everything in my sig, and want this hp goal. I know about the gsk, injectors, turbo, and all that i just dont know what combinations work good. I mean what injectors go good with what turbo to get me my hp goal. Twins arnt an option for a turbo so this makes it a bit harder. Money isnt that big of an issue here either. Please name the products and where you got them.
thanks
Old 07-02-2010, 09:34 PM
johnyb59's Avatar
Get ya some 5x.012's and a 64mm turbo and that should easily get you to your target.
Old 07-03-2010, 08:30 AM
im looking at this turbo i found, what do you think? Ebay ads not allowed on DTR
Old 07-03-2010, 10:49 AM
J Lent's Avatar
I think you'd be much happier with a Super B or similar.
Old 07-07-2010, 12:38 AM
Beast2B's Avatar
just remember those 38s are gonna kill the hp on a dyno. my setup gets 475-ish on a stock height truck with 265s, but I pulled 435hp 1000lbs of torque with 37s
Old 07-07-2010, 03:52 PM
BigErksG2's Avatar
The bigger tires might actually help you because they will load your engine a little better due to the mechanical disadvantage of your truck on the dyno as most dynos can't properly load a diesel.
I'd say head studs, 5x.012's, 4k gsk, and a 62/68/14 from Engineered Diesel. The 64 might be a little tough to tow with if you went with a 64/71 or you might get surging with a 64/65. As soon as you move the fuel plate, you will need to get your auto built up.
Old 07-07-2010, 07:45 PM
my trans must have some work to it because my truck did have some work and it held up fine. i got that 62/62/14 turbo on its way along with a 4gsk.
Deezel Nate
17
12-10-2007 02:54 PM
camshaw
07-10-2007 01:00 PM
dodgezilla04
31
11-13-2006 01:22 PM
65fury
09-10-2006 11:40 PM
streetsmoker
11-03-2005 06:13 AM
Quick Reply: how to get 450hp
