Gearing HELP
Gearing HELP
I have a problem with the rearend gears in my truck, does anyone know of any 3:08 ring and pinions available ? Kinda urgent I get this truck up and running ASAP. Otherwise i will have to change ratios.. Will any of the ratios fit the front axle or will I have to swap out both front and rears to accomplish this change if I cannot locate r&p for the rear ? 90 w250 with the 727 tranny and the 3:08 gearing Thanks in advance Walt..
aren't parts for those axles discontinued?
most guys buy a second axle just for when this happens. That way, they aren't down for a long time.
I could be wrong but it seems that's what I remember reading somewhere or another.
Yes parts a discontinued.
Keep checking the classifieds on all the forums, They did use alot of them because every 89-91.0 auto truck has them and we know how many auto trucks were made over 5spd......
they're out there,
they're out there,
Are the front axle gears interchangable ? as in can I change ratio in the front axle without swapping it out ? I might just drop a 14 bolt FF axle in the rear and change the front gearing to match it..
The front is a Dana 60 used for many years so the gearing is interchangeable. Just remember with the 727 if you change the gear ratio don't go any lower then a 3.23 or 3.55 because your cruising speed is going to be greatly reduced.
Ya I know about the speed...... Plan is to dump an overdrive tranny and drop the gears to 3:55 or so to gain more low end grunt. for plowing without making so much noise in the middle of the night
The rear axle has a offset pinion location also. Your cheapest way out is an axle change out if you can't find an R&P or axle assy.
BTW give me a few days. I know a local guy that striped a 1st gen nonIC 4x4 auto truck last summer. I know the front axle is gone. I am not sure on the rear axle.
I located a ring and pinion in a 93 ram 250 dually. He said its a dana 70, Are them gears the same as the ones in my truck ? Both 3:07... Its a cash for clunkers truck !
They will say on the pumpkin. Mine says "3.54 LS" Or just turn the wheels once and see how many times the shaft rotates. It's most likely a 3.54 or a 4.10 though.
