Gear speed calculator
Old 07-18-2011, 10:35 PM
sootnsmoke's Avatar
I am looking for a gear speed calculator with the gear ratios of the G360 5 speed. I have an excel spreadsheet calculator which works great but it only includes RPM speed calc data with rear end ratio and tire size for NV5600 5 and 6 speeds and NV4500. Are the gear ratios similar between the G360 and NV4500?
Old 07-18-2011, 10:57 PM
BILTIT's Avatar
Getrag G360 5 Speed Gear Ratios:
Gear:
1 5.53
2 3.02
3 1.60
4 1.00
5 0.77
R 5.03
NV4500 Gear Ratios:
(95+ GM, all Dodge)
Gear:
1 5.61
2 3.04
3 1.67
4 1.00
5 0.75
R 5.61*
*Reverse changed to 5.04 approx. 1998 model year.
What exactly do you mean by a gear speed calculator?
A ton of calculators here:
http://www.wallaceracing.com/Calculators.htm
Old 07-19-2011, 12:18 AM
sootnsmoke's Avatar
Thanks. Since I don't currently have a tach in the truck I wanted to find out the max speed in each gear given 3,000 RPM, 4.10 gears and my current tire size.
Old 07-19-2011, 12:27 AM
Mike Mc's Avatar
84 mph if you have a 29" tall tire and 87 mph with a 30"
Down at the bottom, the last three options have good calculators for figuring RPM, speed, and tire size.
http://www.avenger-valkyrie.org/tech...alculators.htm
Old 07-20-2011, 02:26 AM
sootnsmoke's Avatar
Perfect, thx!
Old 07-20-2011, 02:51 AM
sootnsmoke's Avatar
My tire size is 235 85R 16 but I am not sure of its size in inches? I believe it is close to a 31"?
Old 07-20-2011, 07:24 AM
BILTIT's Avatar
Specification Sidewall Radius Diameter Circumference Revs/Mile
285/85-16 9.5in 17.5in 35.1in 110.2in 575
but i think you meant 285/65-16 which is:
285/65-16 7.3in 15.3in 30.6in 96.1in 659
so yes 30.6, close to 31.
Old 07-20-2011, 10:21 AM
sootnsmoke's Avatar
I will double check today but I am pretty sure the outside dually tire I was looking at stated 235/65-16. If correct, I take it that would be quite a bit smaller than 31? Also, I do remember that the factory door sticker stated truck came with 215's
mechrisme
0
12-16-2011 08:41 PM
ValkSmile
01-23-2007 11:42 AM
pappyman
01-31-2003 01:37 AM
thatguy
11-15-2002 10:53 AM
Quick Reply: Gear speed calculator
