Gear shift label turning
Old 08-17-2003, 08:26 PM
jnaker's Avatar
My shift pattern label on the top of the gearshif for my 6 speed has turned about 90 degrees. Just cosmetic, but has anyone had the same problem and how do you turn it?
Old 08-17-2003, 08:50 PM
mymaur's Avatar
Re:Gear shift label turning
Yea they spin. It's the plastic gizzmo that has the shift pattern on it. Three options. 1. take it to the dealer, loose the truck for a day and they wil put it on straight, then it will start to rotate again. 2. take a very smal kinfe and pop it off, glue it on in the position you want and problem solved. Or 3, let it go. You know where the gears are I assume, so forget it.
2 cents.
Old 08-17-2003, 09:13 PM
jnaker's Avatar
I think I will go for option 3. Ive tried to pry it off but was afraid I would mess up the rubber around it. I think I know where the gears are?
Old 08-17-2003, 09:21 PM
Mexstan's Avatar
Read the recent long thread on this. Last week? Or was it the week before? Time flies when you are having fun - reading DTR stuff.
Old 08-18-2003, 08:47 AM
bulabula's Avatar
Nope, not too much discussion on this topic. But if you're interested, click here. Last I looked it almost had a thousand views.
Old 08-18-2003, 09:17 AM
Thats MR Hoss to you buddy!
Hoss's Avatar
Test
Old 08-18-2003, 09:21 AM
Mexstan's Avatar
[quote author=bulabula link=board=20;threadid=18515;start=0#msg173839 date=1061214426]
[/quote]
bulabula, a thousand views ??? Bet you have been told a million times not to exagerate
Old 08-18-2003, 09:46 AM
bulabula's Avatar
[quote author=Mexstan link=board=20;threadid=18515;start=0#msg173852 date=1061216503]bulabula, a thousand views ??? Bet you have been told a million times not to exagerate
[/quote]981; close enuf for govt work.
On edit: Ooops, now its 985.
Old 08-18-2003, 09:59 AM
Hoss's Avatar
986...
Stan...he said almost 1,000 views... :P
95yukon
12-28-2007 04:36 PM
Awall
05-16-2007 08:14 PM
iaddiesel
11-11-2006 03:57 PM
PK
05-26-2005 10:02 AM
adykstra
10-18-2004 12:32 PM
Quick Reply: Gear shift label turning
