Gear shift knob
Old 05-08-2006, 12:38 AM
mvanhelden's Avatar
Gear shift ****
Does the gear shift **** come off on a 99' 5spd? If so how. I have tried twisting it but don't want to hurt the tranny. Want to install a hurst shift ****, is it possible or to your have to tap threads on it.
Old 05-08-2006, 05:30 AM
jrs_dodge_diesel's Avatar
I believe it just screws on. Don't know how much force is required to get it off though. A good strap wrench might be useful if you have one.
Old 05-08-2006, 10:26 PM
GlennRMK's Avatar
The threads are 10x1.5
It just unthreads. The only hurst that will fit is the T-handle.
I'd look into some other *****.
Old 05-09-2006, 02:04 AM
Dieseldude4x4's Avatar
It just threads off. I have the Hurst shifters on the gear shift and the four wheel drive shifter too. Got pics somewhere.
Old 05-09-2006, 02:48 PM
rfcom's Avatar
Maybe 99's are different, but on mine you have to pop out the button on the top of the **** and then remove a lock nut. The **** then screws off.
Jim
Old 05-09-2006, 04:43 PM
slim51015's Avatar
Jim
Mines the same way on a 2001
Old 05-09-2006, 07:14 PM
Dr. Evil's Avatar
Yup. Very carefully pry the plug out with some small screwdrivers and use a 15 mm deep socket to loosen the nut and unscrew the ****.
Old 05-09-2006, 09:23 PM
Pooter's Avatar
Had one on mine for a bit till I stripped the threads out...
All you need in an insert to run larger holed *****...
Thats what was in my T-handle...
Old 05-09-2006, 10:07 PM
displacedtexan's Avatar
I had a 99, it just screwed off, took a little effort the first time, not that much though...
LonCray
66
07-15-2004 08:27 PM
MikeyB
06-23-2003 12:58 PM
BigBlue
12-14-2002 04:09 PM
blackboat
10-21-2002 10:00 AM
Quick Reply: Gear shift knob
