GDP fuel system?????
Old 03-27-2007, 10:37 PM
THE 0NE's Avatar
i have a 2003 dodge and want to run the gdp fuel system but i am mounting a fuel cell does the gdp kit bypass the stock fuel pump completley? or will i have to put a in take pump in the cell????? and run the system in conjunction?
Old 03-27-2007, 10:41 PM
bekim's Avatar
For a 2003 with the pump on the filter cannister, it would be bypassed. No in tank unit is necessary. You can look at the install instructions on the GDP site.
Mike
Old 03-28-2007, 08:17 AM
bdewey's Avatar
The fuel system is bypassed you remove the filter mounted pump and install their billet adapter and the new lines goes off of that to the new Walbro pump. Easy to install don't worry.
Old 03-28-2007, 08:53 AM
lniemeyer2's Avatar
Yep, what bdewey said. I just installed one for a buddy last weekend, it's what I will be doing when my stocker fails or I get some extra cash.
Old 03-28-2007, 12:44 PM
THE 0NE's Avatar
ok sweet so i am hoping i can just plug it in ti thr bottom of the fuel cell and hook up a return line somewhere and be good? does anyone know of a truck with this fuel system and a aftermarket cell??? thanks
Old 03-28-2007, 03:53 PM
lniemeyer2's Avatar
Everything's in the kit from DTR. Just remove the old pump and follow the directions for installing the new one.
Old 03-28-2007, 09:24 PM
bdewey's Avatar
as long as fuel cell has return line and pick-up line you are good. Should be no problems. The pump mounts on the frame. You then mount the billet adapter on the filter canister and run your rubber hoses. Real basic set up. Kit also comes with the wires to power pump off old pumps power connecter.
Old 03-28-2007, 11:14 PM
THE 0NE's Avatar
yeah the cell has two outlets than two vent holes on the top would anyone know what one to use? i am using the jazz fuel cell. 32 gallon than for the extra length i am using the blue push lock hose from summit racing
Old 03-29-2007, 08:56 AM
lniemeyer2's Avatar
Ooops! Sorry I missed the part about the seperate cell, just go with what bdewey said.
Old 03-29-2007, 10:52 PM
bdewey's Avatar
Usually your return line is smaller than the pick-up line. The pick-up line is 3/8" and the return usually 1/4" or 5/16". The pick-up usually is always bigger of two.
AH64ID
66
12-20-2012 08:09 AM
diggity dodge
05-03-2008 12:42 AM
RonP
04-26-2008 01:32 PM
jgiachino
07-10-2007 06:36 PM
wap
23
12-24-2006 01:44 PM
Quick Reply: GDP fuel system?????
