GDP Comp Kit
Old 03-31-2007, 10:50 AM
Megaramasaur's Avatar
GDP Comp Kit
When you replace the spring with the upgraded spring, are you supposed to take out the 1/8 inch washer thats in the short end? I lost my instructions...
Old 03-31-2007, 11:44 AM
Sapps's Avatar
Taken from www.glacierdieselpower.com
http://www.glacierdieselpower.com/im...mp-Install.pdf
Installation Manual
GFS-392 COMPETITION
P/N 3920506C
Competition Bypass Tuning Instructions
All GFS kits for 3rd gen trucks come with the bypass set for 22 psi. With the GFS Competition Systems we supply a bypass tuning kit. This kit consists of a heavier base spring (p/n 15) rated at 22 psi and a set of shims. Each shim set consists of 3 ea .040” brass shims and 2 ea .020” brass shim. The combination of the heavier base spring and the appropriate shims will allow pressures to the 40+ psi range. The number 15 base spring when used all alone will
provide 20-22 psi and the heavier base spring plus 3 of the .040” shims will provide about 42 psi. The .020” shims are used for small increases and fine tuning. When raising pressures above the 30 psi mark we recommend a billet fuel filter lid for the stock canister. We’ve experienced no failures of the stock lid in the 30 psi range but it’s just good insurance. When changing to the heavier base spring you must ensure that all of the shims have been removed along with the softer number 12 spring. Shims are only to be placed in
the short “cap” end of the bypass. Failure to reassemble the bypass in the correct order can result in excessive fuel pressure.
diggity dodge
05-03-2008 12:42 AM
Megaramasaur
03-10-2007 09:59 PM
yelloz28
11-06-2006 08:01 AM
SolarYellow05
09-10-2006 09:14 AM
SSminnow
05-23-2006 10:21 AM
Quick Reply: GDP Comp Kit
