Gauges
I'm sure its one less zero there....and is your pyro before or after the turbo? If your pyro probe is placed after the turbo ( like mine is ) add 10 degrees for each pound of boost.
If you are pre-turbo, I'd say 1200 or so. There is quite a bit of info here if you do a search on "pyro", you may find guys hitting higher temps, athough for shorter durations only. I am hitting the same temps as you, but am waiting to load up a trailer and find a hill in these bald hass prairies to see what the pyro will hit on a load.
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
estesbubba
07-18-2006 04:35 PM
AggiePhil
01-30-2005 01:15 PM
