Gauge mount
Old 12-24-2008, 11:35 AM
pcgym's Avatar
Gauge mount help...
I am getting ready to install my gauges. I am doing the single pillar with the handle, and the 2 gauge column mount... I was thinking about mounting the 4th gauge where the cigarette lighter goes (never use it anyway) to keep them all close without blocking my view. Has anyone done this before and if so, which one should be mounted there? I was thinking that any temp gauge might be affected by the air duct... so maybe the pressure gauge should go there? Mine's an '04 auto. Thanks in advance-
Old 12-24-2008, 12:07 PM
93-331-29psi's Avatar
why not an indash triple pod if you need 4 total? I personally am leary about cutting up the dash for mounting anything because you only get one chance.
Old 12-24-2008, 12:12 PM
silverrhino's Avatar
Do the three gauge mount above the rear view mirror. This way you have the other three gauges together.
Old 12-24-2008, 12:52 PM
pcgym's Avatar
Hey thanks for the suggestions. I would love to do the dash mount... had it before but this truck has heated seats. I also had the triple pillar mount before but actually dislocated my little finger on the upper gauge mount while
correcting a fishtail spin with the tilt wheel up. I didn't like looking around it all the time either. I wish I could see an overhead mount in person... is it hard to keep up with trying to monitor everything and watch where you are going as well?
Old 12-24-2008, 05:56 PM
mpracehemi's Avatar
I'll be changing from a bullydog pmt to gauges. I'm going to be installing the dash mount to install 2 boosts and egt. I'll still keep fuel press., oil press, and trans temp. on the steer.column. All my gauges in close loc. to do a quick glance and still keep my eyes on the road.
Old 12-24-2008, 07:02 PM
pcgym's Avatar
I'm thinking the same way about keeping them close. How are you mounting three to your column? If I could pull that off and make it look clean I would like to try that-
Old 12-24-2008, 11:46 PM
mpracehemi's Avatar
Check in my pics., go to jegs to buy the column mount.-autometer brand
Old 12-25-2008, 07:57 AM
mpracehemi's Avatar
Here's a couple part #'s for jegs (.com); steer. column. 105-15014 and dash mount ( 2 gauges- 2 1/16th size gauge) 105-15020 ( 3 gauge- 2 1/16th size gauges), on MY steer. column I mounted a pod in the middle.
Old 12-25-2008, 10:20 AM
pcgym's Avatar
THAT will work perfectly... thanks for the help-
Old 12-25-2008, 11:02 AM
mpracehemi's Avatar
Glad to help.........MERRY CHRISTMAS!!!!
J10495T
09-21-2011 04:07 PM
chw
12-25-2006 04:30 PM
12valve@heart
08-11-2004 03:43 PM
Bobp
03-15-2003 01:24 AM
rshelton88
12-02-2002 03:52 PM
Quick Reply: Gauge mount
