Gauge install
Old 02-14-2010, 11:23 PM
Berge9798's Avatar
Gauge install
Installing gauges on my 03 and i have a question about installing the boost gauge. Is it better to tap a hole in to the intake horn or to get the boost bolt that goes in to the manifold? i have the drill bit and tap to put it in the intake horn but would it be better in the manifold?
Old 02-15-2010, 08:26 AM
CD in NM's Avatar
When I first installed my gauges I used the bolt in the intake plenum. When I got an aftermarket intake horn I moved my boost connection over to the intake horn. The boost readings were the same regardless of location. I guess it's best to say - your preference/choice, both locations work fine.
CD
Old 02-15-2010, 11:50 AM
Berge9798's Avatar
ok thanks
Old 02-17-2010, 09:23 AM
cdennyb's Avatar
Location: In Oroville, Ca., same house for past 46 yrs!
I made an intake manifold tube for mine and put a pressure tap port in it. Works good so far.
spooled142
03-19-2009 09:10 AM
ado2b1
07-06-2007 10:27 PM
QWKRTNU
09-26-2006 10:22 PM
BigK
25
03-28-2003 07:31 PM
Quick Reply: Gauge install
