what gauge do you think is more important to have?
debating on getting a rail pressure gauge or boost gauge? What gauge do you guys think would be more important to monitor?
That's a tough one as both are important in monitoring performance of your vehicle....and if you're not hitting optimal rp or boost, you're not getting your $'s worth for perf mods out of the truck...not sure how much pressure the BD can build or how agressive it is...but if it's a heavy pressure runner you could be draining the rail and not knowing it...especially w/ out fuel pump....on the flip side, if you're not boost fooling or have a boost leak...same thing...i had the boost guage first and then added rp / fp later...
Reasons for RP Guage - tell you if you're draining the rail, ensure you're not cruising at 20+k psi (bad for fuel system for extended periods)....maybe sign of clogged fuel filter (but think that's the fp guage)...
Reasons for Boost Guage - tell you if you're building optimal boost, boost fooling, boost leak....max boost
Get'm both....nice truck....i bet the 37's and 6" lift look sweet....
Thanks! Good info you gave me!! I just put my truck on the dyno this weekend and hit a peak of 399 hp and 780 ft of torque. Thats not allot but is good for me. I am trying to make my motor last 500,000 miles. just thinking i should monitor some more so it will last. So from what you are saying i think the fuel or rail pressure gauge might be more important as far as safety for the motor? i would like to get both, but i only have the pillar with 3 holes, and don't want to put anything on the dash.
If you want it to last 500k then take it back to stock and get a nice fuel filter setup. Mine lasted 140k and the rings went, not that all do but if you push 4-5-600hp then probably expect it to last only twice as long as a 6leaker
I would say the boost gauge has a higher priority. RP gauge is one of those nice to have items, but not mandatory unless using large amounts of duration, larger injectors and a pressure box.
MikeyB
MikeyB
BOTH are important.
When I bought my truck I installed EGT, BOOST and FP, the typical 3 most people put in a truck with a standard tranny. When I had issues with the rail pressure relief valve, my dealership was unable to make it fail or duplicate its problems under their 'normal' 2-3 mile test drives. I put in the RP gauge and was able to report to them the dips in pressure, fluctuations took place when holding the throttle steady. Their tech too my truck for a drive, tried holding the throttle steady, saw the fluctuations and replaced the rp relief valve based on that information. 40K+ miles later, my rp is as steady as a rock.
Every gauge has it's value/merit, depends on how you see it's benefit and what you want to monitor. The rp gauge will tell you when your CP3 is having a problem as well. The boost gauge will tell you about how your turbo is functioning, both are good to have.
CD
CD
Think i am going to get a boost gauge first, then a RP gauge. JMMCDONA think i will get the steering column mount like you were saying. looks like it will be good and is a good price. Eventually i will be getting both gauges tho, when i get some more money kicking around.
RoadDiesel
12-29-2014 09:11 AM
BigDan
11-07-2006 12:05 AM
VikingDiesel
Competition / Pulls / OffRoad
06-05-2006 08:52 PM
