Gauge & chip advice needed
Old 08-28-2010, 09:31 PM
Duck Soup's Avatar
Looking to add a fuel pressure gauge and am looking for input on which one to go with. Also thinking about a power boost and looking at a chip, any advice here?
Old 08-29-2010, 12:44 AM
wyododge's Avatar
I went with Autometer. You can get them in the DTR store. PM Lary Elis (Top). Lots of Banks, Smarty, and BD. It kinda depends on what you want to do though.
Old 08-29-2010, 08:14 AM
98whitelightnin's Avatar
I use a mechanical Di Pricol gauge and edge comp, the gauge matches the dash gauges pretty good and the comp is a good box. Instead of a pressure isolator I used a needle valve from napa and ran fuel into the cab. If it ever springs a leak I can just close the valve and replace the tubing.
Old 08-29-2010, 10:20 AM
nickg's Avatar
do the math first, usually 3 gauges and pod plus a chip will cost as much as an edge juice/attitude or ADR, I did it the hard way, edge EZ plus gauges, (800$) then later on I switched to the EDgeJ/A (740$) all prices Canadian.
I pretty much gave away my old set up as I got nothing for it, now if you can score a used chip/gauges for cheap you would be ahead of the game
while some perfer mech gauges, I like the ability to set warnings/limits on my monitor, this means I dont have to watch my gauges all the time as an audiable alert will pull my eyes off the road to have a peek at the gauges
Oh, and some like to claim that mech gauges are more accurate, I ran both at the same time and did not see that result
my two cents
Old 08-29-2010, 02:14 PM
sheriffav8r's Avatar
Edge Juice with Attitude. Gives you everything you need, and then some. Turbo timer and alerts/limiters are priceless....
Old 08-29-2010, 09:46 PM
Duck Soup's Avatar
Thanks for all the input guys. I appreciate it.
gergthegreat
12-30-2008 09:19 PM
bansh-eman
01-27-2008 02:48 AM
Elk_Hunter
10-24-2006 03:17 PM
cowdude
02-19-2003 06:20 PM
Quick Reply: Gauge & chip advice needed
