gas tach conversion
Old 04-01-2010, 09:03 PM
ttcfan4476's Avatar
gas tach conversion
i think this will work for both 12v and 24v but i did a 12v so here it is you only need a phillips screw driver
remove the threee screws from the back of the tach
i got the gas cluster from my parts truck and took the cover off
i belive there is seven screws
then you can remove the tach gauge and do the same process on the diesel cluster and you can have a gas tach
Old 04-01-2010, 10:42 PM
CTD12V's Avatar
That is cool! I wish it would work for the 98 and up style dash, but I'm pretty sure they are all one unit.
Old 04-01-2010, 11:42 PM
Tate's Avatar
Why not just swap in the whole cluster? Only thing that changes would be the mileage.
Old 04-02-2010, 02:16 AM
ttcfan4476's Avatar
i wanted to keep my correct milage
Old 04-02-2010, 12:06 PM
patdaly's Avatar
Are you sure your RPMs are correct? At least on the GM vehicles, 6 and 8 cyl. tachs took different electronics, made it hard to swap clusters into our 9C1s.
They had differing resistors IIRC.
Old 04-02-2010, 02:37 PM
Tate's Avatar
They read the same, its through the PCM. I've got a gas cluster in my 24v, its bang on to the tach on my timing light.
Old 04-02-2010, 09:18 PM
ttcfan4476's Avatar
60 mph at 2000 rpm is still the same
Old 04-03-2010, 11:46 AM
patdaly's Avatar
Cool!
cappykd
06-23-2008 04:45 PM
97' CTD
06-09-2008 04:58 AM
THURENfab.
08-08-2007 07:02 AM
Scovo1
30
05-11-2007 01:08 PM
04ctd
15
04-30-2006 08:45 AM
Quick Reply: gas tach conversion
