gas gauge light out
If I remember correctly, you need to pull the trim then there are 4 screws that hold the cluster in (and a couple of connectors in the back after you pull the cluster away a bit). Been awhile, so someone else chime in here. As for changing the bulbs, dim the cluster lights to off or almost off, then tear things apart and change the bulb, when it is all back together, turn on the headlights and slowly bring the cluster lights to full brightness again.
ya thats about right. take off your kick panel. (the piece infont of your knees) then the piece around the radio. only one screw. (its near the glove compartment) then get the peice around the cluster. then a bunch of philips head screws hold the cluster in. change the bulb and your done. hope this helps buddy
oh ya dont forget about the two screws in the bottom of the kick pannel. and the few things that plug in here and there (they are easy all color and size diff)
paroxysym
05-27-2008 07:12 AM
THURENfab.
08-08-2007 07:02 AM
Scovo1
30
05-11-2007 01:08 PM
