Gas/diesel tanks, what's the difference
Old 11-19-2010, 08:52 PM
ClassA4x4's Avatar
I'm swapping a Cummins into my gas-powered Class A motorhome. Can I use the 50-gallon gas tank for diesel?
Old 11-19-2010, 09:06 PM
simplysmn's Avatar
Yes there is no reason why if it has a intank pump you may have to change it
Old 11-20-2010, 07:59 AM
ClassA4x4's Avatar
The motorhome has no in-tank pump, the fuel pump is all mechanical. But wouldn't a low pressure inline/in-tank pump be helpful to the Cummins?
Old 11-20-2010, 01:19 PM
MrExtreme's Avatar
You will want to drop the tank and remove the strainer sock from the end of the feed tube. I had a problem with that and could not figure why fuel would not feed, I guess that strainer is too fine to flow diesel well.
gts95
07-28-2009 12:31 PM
Mcc2430
11-01-2007 05:53 PM
ocsurf16
09-25-2006 10:36 AM
tacoma
07-25-2006 07:47 AM
Quick Reply: Gas/diesel tanks, what's the difference
