G56 problems
Old 06-11-2008, 10:35 AM
Pack Mule's Avatar
G56 problems
is anyone else having problems with the G56?? i'm on my 3rd one, and the 2nd only lasted a couple thousand miles before i lost 1st and 2nd shift forks and locked up the tranny. now the current one with about 1000 miles sounds like a bearing is about to sieze up. i'm just curious if i'm the only one having problems with these.
Old 06-11-2008, 10:48 AM
rich's Avatar
no i had mine go out on the 07 it started around 10 k they replaced it at 51 k put 17k on it before the motor went
Old 06-11-2008, 12:52 PM
Roperteacher's Avatar
Sure haven't had any issues with mine and I use it pretty hard! You sure don't hear of many problems with the G-56. I have the newer updated one (AE) that has the taller 6th gear. THis in in my 07 5.9. I changed out the mopar fluid immediatly to Amsoil and sure don't have any problems.
Old 06-11-2008, 08:31 PM
bway1341's Avatar
46000 miles and running strong
Old 06-11-2008, 08:43 PM
MMMmmmm.... Grits!!
ratlratl's Avatar
60K and well so far..........
Chris
Old 06-11-2008, 11:35 PM
RAMRODD's Avatar
No problums yet, and it gets used hard!!
I think I would demand a new tranny not a rebuild
Old 06-11-2008, 11:44 PM
DmaxEter's Avatar
65,000+ on mine and I love it! If I can figure out a way to fit one in a project Jeep I will have one in it too!
Old 06-11-2008, 11:49 PM
With age comes the cage
Colo_River_Ram's Avatar
Do a search on this, I recall a post about how some of the G-56's were damaged at the factory by forklift transport..
Old 06-12-2008, 03:16 AM
chipmonk's Avatar
yup, lots of g56's were damaged when they were moved around by fork lift while uncrated. dodge has had to repair thousands of leaking g56's because of this.
Old 06-12-2008, 09:13 AM
AH64ID's Avatar
My dad's 06 has 35K on it most of which are towing, other than he says my NV5600 shifts much easier its in good shape.
Old 06-17-2008, 11:01 AM
marty649's Avatar
80,000 mi and no problems
Old 06-17-2008, 11:44 AM
snoyes's Avatar
Haven't had any problems with the G-56. Now the stock clutch on the other hand didn't like the 35s and the Smarty on level #5...
Old 06-17-2008, 11:50 AM
marty649's Avatar
I had similar problems when I added the Quad box, floor it in 5th or 6th gear and it would slip, added the South Bend OFE clutch and haven't had a problem since. 40,000 mi on the SB so far...
Old 06-17-2008, 12:21 PM
tool's Avatar
Love my G56, best truck tranny I have ever had to date.
I haven't heard of any complaints from my buddies who run them either.
Old 06-17-2008, 01:20 PM
D-Roc's Avatar
I wonder what 4.10's w/G56 on stock tires would be like.... No highway time, (or limited) that's for sure!
Quick Reply: G56 problems
