G56 Owners FYI: Amsoil vs. Valvoline
Old 05-03-2011, 03:10 PM
00Dog's Avatar
I switched out my Amsoil ATF+4 today for Valvoline. The shifting difference is night and day. It shifts like a BMW again. I still have the Amsoil in the transfer and diffs but my tranny didn't like it.
Old 05-03-2011, 03:37 PM
ripping r's Avatar
I run the napa atf+4. i think amsoil is overrated and over priced. I think the napa stuff is Valvoline just in a napa bottle.
Old 05-03-2011, 03:46 PM
SpeedyWS6's Avatar
Shifts like a BMW or like a Mercedes?
Old 05-03-2011, 04:29 PM
00Dog's Avatar
Ok you're right. I've only had a Mercedes with an auto... until now.
Old 05-03-2011, 10:12 PM
rockcrawler304's Avatar
I just run the Mopar ATF+4 and have since new. No issues so far. I may try Valvoline next just to compare.
Old 05-03-2011, 11:12 PM
SundayMoney's Avatar
I had the same experience with Amsoil. My truck doesn't shift worth a darn when its cold. I tried Amsoil to see if that would help. If anything it got worse. Back to Valvoline ATF+4.
If its going to be hard to shift either way,I may as well use the less expensive fluid.
Old 05-04-2011, 08:48 AM
LOWTYD's Avatar
Noticeable difference?
Do you guys feel a noticeable difference once you change out the stock fluid. I have about 170,000 on the stock fluid. I bought everything to change it out, but once I checked it, it looked fine, so I put it off for a while. Plus, its a PITA to get to the fill plug around the exhaust pipe.
Old 05-04-2011, 09:03 AM
DTR 1st Sergeant
soulezoo's Avatar
Hmmm....
If it shifts like my Mercedes, then I'll stay with the amsoil!
Old 05-04-2011, 09:58 AM
Buy one of the pumps that fit gallon jugs,and pump the fluid into the tranny.
I use an old washer fluid jug I saved.
The service interval is 60K IIRC. I'd be changing the fluid out regardless of whether it'll shift better.
Old 05-04-2011, 12:54 PM
sdaly's Avatar
I've used Mopar ATF+4, Castrol ATF+4, and Redline C+ ATF in my G56. The Castrol ATF+4 has been the best in my experience, and it's also the least expensive, and widely available. The Mopar ATF+4 looked pretty done when I'd change it--a dark brownish-red. But the Castrol under the same conditions always drains out looking bright red, like new.
I had to cut down the hex socket to remove my fill plug so it would clear the exhaust pipe, otherwise it's pretty easy to remove. Then I use one of those flexible fill hoses that screws onto a quart oil bottle to fill 'er back up. I jack up the right side of the truck a bit and fill it until it's dribbling back out, then button it back up.
Old 05-04-2011, 02:04 PM
LOWTYD's Avatar
Sounds good! I think I'll try jacking up the right side like you said, just to get a little extra in. I think that would be easier than taking the boot off.
DirtEater
11-13-2010 01:39 PM
Utundra
08-09-2009 11:07 AM
Blacked Out
05-22-2009 07:46 PM
2006 MEGACAB
38
09-10-2007 12:24 AM
Quick Reply: G56 Owners FYI: Amsoil vs. Valvoline
