fuel system question(airdog)
Old 07-23-2008, 02:18 PM
motochamp250's Avatar
i'm heavily considering the 100GPH airdog system and was wondering what ya'll thought about it and how it would work with the '02 that is in my sig? ...thanks in advance....i looked at fass, but airdog doesn't look much different and for a few dollars over 500 it seemed good to me?....also how much would it take to start pulling hte 100GPH down to dangerous levels? would the adrenaline do that or are we talking serious horsepower? i will be adding a stronger chip later but no plans to get super crazy...
Old 07-24-2008, 03:31 PM
bump......
Old 07-24-2008, 03:35 PM
Mcmopar's Avatar
I installed one on a customers truck, he loves it, but...mods are at a minimum.
Old 07-24-2008, 04:51 PM
scottsjeeprolet's Avatar
I run the Adrenaline and the AD 100. Can't pull it below 14psi. It's a constant 18psi cruising.
Old 07-24-2008, 05:30 PM
AH64ID's Avatar
The main thing that steered me away was the ratings of the filters, mainly the water sep is 140 microns, which isn't bad for a gravel trap but is only rated 50% for removal of free water and 0% of emulsified water, and is only rated for 19 GPH on a 100GPH system.
Old 07-25-2008, 01:39 PM
how hard is the install? does it come with EVERYTHING needed?
Old 07-25-2008, 01:54 PM
The AD 100 is pretty simple. the 150 requires dropping the tank for the draw straw. And it does come with everything except the fitting for a FP gauge line. I made my own fitting.
I like getting all the old stuff (FF & LP) off the side of the block. The AD wire harness is pretty good too, plug and play. The green wire will throw you off, i just cut it out of the harness. I think it's green, it's for something else.
Old 07-25-2008, 01:57 PM
ya thats most of the reason as to why i went with the 100 was to stay away from dropping the tank and such.....my FP gauge is not currently hooked up so i was going to get fittings and things for it after the install anyway, so that is really no problem.....whats the green wire for? lol and does it tell u where to mount it or is it just put it where you want it?
Old 07-25-2008, 02:38 PM
Administrator/Jarhead
madhat's Avatar
Would you elaborate on this a little?
Old 07-25-2008, 03:02 PM
AH64ID's Avatar
What more do you want to know. Pureflow put out the Fleetguard part numbers and I got the specs...
Old 07-25-2008, 05:09 PM
Well then post them up so we can all see them. I'd like to know more about what you are saying too and i'd like to have the Fleetguard numbers as well.
Old 07-26-2008, 08:37 AM
Fuel Preporator's Avatar
Hi Everybody,
Sorry about being off the posts for so long, we have been moving into our new 38,000 sq. ft. building.
About the water separator. The main purpose of the wire screen element is to filter out water and large particulates that could/would jam the gearotor and/or plug and block the incoming fuel flow either of which would shut the system down. Under high flow and high pressure conditions you can force water through anything. (You can cut steel with a water jet) But hold on, the AirDog 2 micron Stratapore filter that fleetguard makes for us is also a water separating media!!! We, PureFlow has had absolutely NO PROBLEMS or ISSUES with the filtration products we acquire from Fleetguard Corporation nor have our customer friends.
One of our class 8 fleet customers reported a phenomenal record of 30 trucks, avg. over 125,000 miles per truck per year, for seven years with ONLY THREE, that's right with only 3 injectors (Total) having failed!! That is what complete fitration with the Fuel Preporator AirDog can do for you. This is the reason I keep the price of our filters reasonable and try to entice all to use them and our dealers to carry them in stock.
That speaks for itself!
Thanks,
Charlie
Old 07-26-2008, 05:39 PM
thanks for the info! so i have one more question...Does it have a specific mounting position in mind or is it kind of just mount it where you want it? and if so where did ya'll mount yours?...ordered mine from the DTR and can't wait for it to get here!
thanks,
Hunter
Old 07-26-2008, 06:50 PM
AH64ID's Avatar
They are FF5613 and FS19768... email fleetmaster.us@cummins.com and ask for the specs on those filters. They will email you a pdf.
Originally Posted by Fuel Preporator
Hi Everybody,
Thanks,
Charlie
I have no doubt its a good system, but the numbers and ratings just aren't there in the filters. Unless I have the wrong part numbers, linky...
The link says 3 micron, but the specs are absolute at 5 microns and 94% at 2. This filter isn't rated as a water sep, you can tell just by the part number.. FF for fuel filter, FS for fuel separator. If it were a separator it would also have a way to drain the water. A separator without a drain is scary, because if it fills with water is sends pure water to your motor, you have no way to remove it.
01blackspeeper
03-23-2012 04:52 PM
Tractor Truck
01-20-2011 01:56 AM
kdbvulcan
20
12-06-2008 04:34 PM
jentas
33
03-07-2008 02:45 PM
vp_mopar
33
01-28-2008 06:35 AM
Quick Reply: fuel system question(airdog)
