Fuel system issues?
Old 09-29-2005, 12:37 PM
sandpuller2004's Avatar
Fuel system issues?
I have been having some problems with the dodge and am not sure what to look for.
3 different occasions my truck has done the following.
get in start the truck wtih out waiting for the wait to start to go out, and i crank and it wont start. try again nothing.
usually end up waiting 20+ minutes and it finally does.
kinda sounds like lack of fuel?
mods are as follows
hypertech programmer set in level 2 (tow mode)
4" mbrp turbo back exhaust/k&n air filter.
otherwise stock truck.
threw a p0336 and a p1693 codes?
also do i plug in to check fuel pressure? the shreader valve on the module on injector pump?
Old 09-29-2005, 01:01 PM
CTD NUT's Avatar
The 0336 DTC is a crankshaft position sensor problem and typically means it needs to be replaced.....it is common for this sensor to cause several different running problems and could cause a hard start problem but I'm not sure on that one. The 1693 DTC is called a companion code and all it means is that there is another code stored within the ECM (usually) that is not retrievable without a scanner. Since you are having a hard start issue, I would suggest you have the truck properly scanned to get the other code. And yes, it is always a good idea to monitor LP pressure regardless if you have a problem or not.....the schrader valve test port on the VP44 inlet is the correct place to measure the LP pressure.
RiverRat2
10-15-2019 10:59 AM
One Way
12-19-2010 04:00 PM
westspeed
11-10-2010 07:52 AM
mykal41
08-27-2008 07:09 PM
Herr Diesel
06-08-2006 09:43 AM
Quick Reply: Fuel system issues?
