Fuel shutoff won't disengage when starting..
Old 03-06-2010, 09:30 PM
HemiDave's Avatar
Just bought a 97 dually to replace the 96 that got wrecked (from a board member). This one runs fine but the solenoid for the fuel shutoff won't open when the ignition is turned on. I have to manually move the plunger up. Gets old fast...
Replaced the solenoid and mount from a running truck, Nothing different. Replaced the relays on the firewall below the hood gasket. Nothing different. So what should I check next? What voltage should be at the solenoid when the ignition is on?
Thanks!!
Dave
Old 03-06-2010, 10:03 PM
sawmill's Avatar
The wire that runs from the battery has a fusible link if blown no power.
Old 03-06-2010, 10:18 PM
HemiDave's Avatar
Cool. I'll check that tomorrow. Just a continuity check should do it, right?
I just found fostertruck.com and see that he has fusible links. I assume this is the best place to get 'em?
Thanks!!
Dave
Old 03-06-2010, 11:13 PM
ET RAM's Avatar
Here is a schematic that may help. The fuselink power wire is what pulls the solenoid to the on position. Voltage is battery voltage.
Attached Thumbnails Fuel shutoff won't disengage when starting..-starter_curcuit_diagram.jpg
Old 03-07-2010, 07:31 AM
blackimpala's Avatar
I have read that it is a blue wire. I don't think a continuity check will do it, it corrodes and the problem is it won't carry "enough" power.
Floyd
Old 03-08-2010, 03:55 PM
FlaCracker's Avatar
I don't know about the 97, but on the 98s Dodge started using a fuse on the fuse panel on the drivers-side of instrument panel instead of the fuseable link from the battery.
Old 03-08-2010, 04:24 PM
Tate's Avatar
The solenoid only pulls up when the starter is engaged. Pull the relay out, and use a multimeter or a test light from the brown signal wire to the ground and check the voltage when cranking. If its low or not there at all, then you may have a corroded or broken wire.
Arsenal
08-10-2009 12:17 AM
roadhermit58
06-08-2009 09:02 PM
deerslayer1979
07-14-2008 10:40 PM
Thundercraft
01-20-2008 10:22 PM
B.A.Ram
05-25-2005 01:06 PM
Quick Reply: Fuel shutoff won't disengage when starting..
