fuel shutdown solenoid
Old 11-04-2011, 08:10 PM
jst652's Avatar
Question fuel shutdown solenoid
can any one tell where any diesel wrecking yards or online used parts are.my fuel shut down solenoid is intermittent.Have to raise plunger to start. Dearler wants 739.00 for a little piece. cant believe the price!
Old 11-04-2011, 10:02 PM
9812vram's Avatar
Best price on fuel shut off solenoid I've seen is on Larry B's site. I think they are $120. Google FosterTruck for his site. I wouldn't recommend putting on used electronics. There's no way of telling how worn they are. Also, make sure it's not the fuel shutoff relay or a bad connection on the fuseable link at the battery. Unless they are sticky (in which case they can be cleaned and put back into service) solenoids usually either work or they don't. Intermittent problems generally point to something else.
Old 11-04-2011, 10:28 PM
plow's Avatar
Mine was doing the same thing few years ago and it was the relay, 15.00 from foster's.
Old 11-05-2011, 12:18 AM
pind's Avatar
for a solenoid, try your local Bobcat dealer. part number 6681513
Usually around 100 bucks, give or take, direct bolt in, plug and play
Old 11-05-2011, 07:44 AM
MNorby's Avatar
Definitely check your relay. Mine was doing same thing and tested and the relay appeared to be working ok with a volt meter but jumped the solenoid with a wire to the battery and it clicked up. Got a relay from Larry B and all is good. I did take my solenoid apart and clean it and replaced my torn up boot while I was there.
Old 11-05-2011, 08:15 AM
jst652's Avatar
Smile thanks again
i cant believe the support you find here.what a great place!!!!
Old 11-05-2011, 10:34 AM
Pickin on the wrong admin...
Diesel Dave2's Avatar
Got mine from Geno garage...Its been a while...I think it was around $135..
Old 11-15-2011, 02:45 PM
TheWaterman1000's Avatar
If you really trying to save money and eliminated any more problems. You can convert to manual shut down. I posted pic's of my conversion. If any question ask...
Old 11-15-2011, 03:21 PM
Robert Rausch's Avatar
Ditto going with a manual conversion.
Start and run position:
Kill position:
Old 11-15-2011, 10:23 PM
ET RAM's Avatar
I installed a manual fuel control also. It is similar to the one pictured but mine has a small round **** and has about a 1.5-2" travel. In my installation I pull on and push off. Cost about $8.00 at AutoZone. It works great.
Old 11-17-2011, 11:09 AM
DieselCountry85's Avatar
Doing this this weekend, can someone post a pic of how they hooked up to the fuel valve arm please?
Old 11-17-2011, 11:17 AM
Here's the bracket I made. The two holes bolt right onto the fuel shutoff lever.
This one's not a great picture, but you can sorta see how it's installed. I cut some of the original solenoid bracket away in order to install my bracket.
Old 11-17-2011, 11:25 AM
Thanks man, thats about what I had planned. I appreciate it.
Old 11-17-2011, 12:59 PM
Dr. Evil's Avatar
Theres some very useful info here:
http://www.dodgeram.org/tech/dsl/tro..._solenoid.html
Old 11-19-2011, 06:18 PM
I would put a spring from the arm to a hole on the outside bottom of the throttle bracket. Helps with the return on the arm to start. Check the photos on how I did it. Best
Quick Reply: fuel shutdown solenoid
