Fuel sending unit clicks?
Old 12-28-2006, 01:58 PM
xtoyz17's Avatar
I was laying under my truck while it was running today and I noticed a clicking/ticking. After a little nosing around, I noticed it was coming from the fuel sending unit on the top of the tank. Is this normal, or something to worry about? No leaks or anything out of the ordinary except for the clicking coming from the unit.
Thanks,
Shawn
Old 12-28-2006, 03:00 PM
lgp9999's Avatar
Mine does the same thing, but I hadn't pin pointed the source of the clicking. My fuel gauge is all over the place... is yours?
Old 12-28-2006, 04:08 PM
xtoyz17's Avatar
Mine's pretty consistent. I guess you could call it a problem if after 240 miles it's at half tank, but I can't pass the blame to the fuel sending unit for that
Old 12-28-2006, 06:43 PM
9812v's Avatar
I noticed that same sound after changing the sender. It seemed to me that it was the return line pulsating as the fuel passes through, not sure if that's what it is though.
Old 12-28-2006, 07:41 PM
ric o'shea's Avatar
Mine did the same thing. It has stopped after i changed the fuel module and the fuel lines to rubber hose. I dont know if that has anything to do with it. My two cents worth is maybe it's the steel fuel lines transmitting the pulses from the IP.
Old 12-28-2006, 08:01 PM
TIMMY22's Avatar
pulse from overflow valve dumping back to tank.
Old 12-28-2006, 08:07 PM
xtoyz17's Avatar
Normal or no?
Old 12-28-2006, 08:17 PM
TIMMY22's Avatar
yea, if it's the extra fuel comming back through your return line it's totally normal. the sound is spurts of fuel chattering through the overflow valve. try a few cable ties around the return line in that area.
Old 12-29-2006, 10:33 AM
infidel's Avatar
It's the same pulsation that kills fuel pressure gauges if they aren't dampened. Totally normal.
Old 12-29-2006, 10:44 AM
xtoyz17's Avatar
Works for me. Just wanted to double check about that odd sound.
Thanks yet again guys,
Shawn
Southern Pride
05-18-2010 07:47 AM
JasonblkZ06
05-16-2009 08:02 PM
powerwagon440
23
03-12-2004 12:44 PM
dcwm
06-13-2003 12:27 PM
figure_9_pro
11-11-2002 08:53 PM
Quick Reply: Fuel sending unit clicks?
