fuel pressure
Old 11-21-2010, 08:28 PM
Exekiel69's Avatar
fuel pressure
I'm trying to get a good spot to connect the line I'll use for a fuel pressure gauge, is there a good spot I could use? I want to put it after the filter and before the IP inlet so I'll know if the filter is getting clogged. On My ford truck I didn't use the cummins filter head so it was easy to cut the inlet line to the IP and put a T there, on this other engine I will keep the cummins filter head so I'd like to know if there is a way to accomplish this with out cutting the line.
Thank You.
Old 11-21-2010, 08:44 PM
Onemoparnut's Avatar
Get a tapped banjo bolt to replace the banjo bolt that has the bleeder screw in it. That is how a lot of people have done it.
Old 11-22-2010, 11:18 AM
blackfordd's Avatar
Don't forget a "snubber" or a "needle valve" or that puppy will jump around on you until the sender finally takes a dive.
Old 11-22-2010, 01:05 PM
92smokin blacky's Avatar
yesss get a snubber cuz i've had my electronic one for only a few months and the sensor already took a dump.
Old 11-22-2010, 04:24 PM
Exekiel69's Avatar
Yes, the one on My other truck is already jumping like crazy, I got a valve I plan to use on it and this one as well. What do You guys refer to as snubber?
Can't I just drill the banjo bolt and tap it.
Thank You.
Old 11-22-2010, 10:34 PM
I suggest getting the banjo bolt from genos. I drilled my stock one bigger and tapped it and also broke a tap while doing it... wow that whole thing was just a big mistake so i say just buy the one thats already to go and save a lot of hassle.
Old 11-23-2010, 08:17 AM
Exekiel69's Avatar
Thank You.
Old 11-23-2010, 05:18 PM
Exekiel69's Avatar
Where can I get this? They have one at the local hardware store but it comes with a rubber seal and I'm not sure it can take the diesel fuel.
Old 11-23-2010, 06:39 PM
blackfordd's Avatar
I think Vulcan has the needle valve.
Old 11-24-2010, 08:17 AM
Exekiel69's Avatar
I found this one and this one Item R7798. Are this the same thing? Doesn't look like they are but do they accomplish the same purpose?
Thank You.
Old 11-24-2010, 05:29 PM
Exekiel69's Avatar
Anyone?
Old 11-24-2010, 06:27 PM
blackfordd's Avatar
I have the R7798 from Diesel Manor.
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
Quick Reply: fuel pressure
