fuel pressure
Old 06-29-2009, 10:46 PM
blownsmok97's Avatar
fuel pressure
I finally got around to hooking up a fuel pressure gauge. I tapped the banjo bolt and ran a line into a guage on the steering column. I put a ball valve, and then a needle valve right after it to keep the pulsations down, and the ball valve in case it starts leaking.
My question is i am seeing about 12 to 14 psi at idle, and about 2000 rpm it tops out at about 18 to maybe 20 psi. I have a holley blue on.
Is it because of the holley? should i get rid of it? is that enough pressure?
Old 06-30-2009, 11:48 AM
Dr. Evil's Avatar
Why in the world would you be running a Holly fuel pump on a 12V Cummins?
You are a starving the injector pump.
Cummins' pressure specs are 17-22 psi at idle, 25-35 at 2500 rpm no load,
Pressure should never drop below 25 psi under load
Old 06-30-2009, 03:48 PM
ya thats what i was thinking, it was on it when i bought it and i just never thought to pull it til recently i got thinking and put the gauge on.
I will pull it asap.
thanks a bunch.
Old 06-30-2009, 04:23 PM
Dr. Evil's Avatar
Does it still have the Lift Pump on the block?
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
Quick Reply: fuel pressure
