View Full Version : What fuel pressure gauge are you running?
vancemxer
01-23-2007, 12:15 AM
I am in the market for a fuel pressure gauge? Just wonder if you are happy with yours and where to buy it from. Thanks
TheBigNasty
01-23-2007, 12:23 AM
Can't speak for all Autometer gauges but, my 0-100psi Ultra-lite has a long threaded AN fitting and does not fit well into the A-pillar. Best we could figure is they make it that way to discourage installation in the cab. [laugh]
Ram1999
01-23-2007, 07:46 AM
I have the ISSPRO 0-30 gauge.
I found it HERE (http://egauges.com/vdo_mult3.asp?Type=Mechanical_Fuel_Pressure&Series=EVA-R&Units=E) for $39.00
I used the steering column mount purchased at the same place for $29.00.
jiMMyCTD
01-23-2007, 07:56 AM
i too have a steering column mount... using a diprocol (i think) white faced gauge 0-30 psi mechanical.. love it...
adidasman23
01-23-2007, 08:12 AM
autometer. i love it because it is so easy. i have used a machanel gauge and hated it.
6WHEELER
01-23-2007, 08:15 AM
Autometer cobalt electric 0-30psi on the pillar. No problems with it after a year of use.
olbetsy98_12V
01-23-2007, 08:16 AM
I have a 100 psi autometer phantom gauge i love it haven't had any trouble with it. I got it and the column mount from www.puredieselpower.com. It was about 30 for the mount and 55 for the gauge.
qwest
01-23-2007, 09:33 AM
0-60 1 3/4 inch test gage mounted under the right side of the instrument cowl,
with a hose retainer clamp.. crude, but easy,,,
vancemxer
01-23-2007, 03:43 PM
Alright. Thanks for the info guys!
infidel
01-23-2007, 06:45 PM
For high quality very low priced gauges check these guys out
http://www.surpluscenter.com/sort.asp?UID=2007012318404056&catname=engines&keyword=NFGA
Remember the gauge doesn't have to say fuel on it, water, oil or air will work just fine.
lwcmattlifter
01-23-2007, 10:08 PM
Isspro here. Make sure you run a snubber/isolator on the mechanical gauges to cut down the gauge rattle.
TxDiesel007
01-23-2007, 10:56 PM
Isspro here
0-60 psi from www.dieselmanor.com, i used a needle valve for a snubber, without an isolator.. waste of time and money to use...
Rick
