Fuel Pressure Gauge
Old 11-08-2003, 08:59 PM
DODGE4X4's Avatar
Fuel Pressure Gauge
I would like to buy a Fuel Pressure Gauge so that I can check my lift pump on a regular basis. I don't want one that mounts to the truck rather I would like to have one that I can just pop the hood and screw in onto the test port. Is there a website that sells these things and is there a brand that someone would recommends?
Old 11-08-2003, 09:17 PM
MonroeDiesel's Avatar
Re:Fuel Pressure Gauge
Search for Briar Hopper Fuel Pressure Gauge. I bought one from Advanced Diesel Technology. About $30 works great
Old 11-08-2003, 09:38 PM
Marine's Avatar
Black Mountain Diesel. Tom is who you want to talk to.
Mike
Old 11-08-2003, 09:44 PM
DODGE4X4's Avatar
Old 11-09-2003, 02:30 PM
10HAAP's Avatar
Checking the fuel pressure at an idle will be of little value. The important test is when the engine is being worked, like at cruise speed and wide open throttle (WOT).
Old 11-09-2003, 06:04 PM
DODGE4X4's Avatar
OK BOYS I'M KIND OF HOT RIGHT NOW > My truck runs perfect without a trailer but, I just hooked up to a 28' cattle trailer with 23 head of caves in it and it didn't run worth a (well you know). I had to turn back around and put the caves back in to the pens > here is what the truck is doing while I am getting up to speed it starts to shudder and acts like it wants to die. When I finally got it up to 65 mph with my OD off it was dropping in RPM and acted like it was down shifting a little bite. SO could this be a LIFT PUMP ??? After I got the trailer off the truck runs like a champ.
Old 11-09-2003, 09:03 PM
Marine's Avatar
It's hard to say, but does it shudder with the puck off under load?
Mike
Old 11-09-2003, 09:10 PM
HammerMTB's Avatar
Can also be the overflow valve
[quote author=DODGE4X4 link=board=7;threadid=22183;start=0#msg207790 date=1068422642]
[/quote]
If the overflow valve is failing, it will give you low fuel pressure, and simulate a bad lift pump. You might want to check that before you drop coin on a lift pump. Don't forget, something as simple as a fuel filter can do this as well! I'd say an air filter, too, but if you're not pouring clouds of smoke, that's not it.
Old 11-09-2003, 10:41 PM
DODGE4X4's Avatar
I don't know if it is the overflow Valve but I will go check it right now. I don't think the Power Puck is causing the problem b/c when my old one would mess up it would throw codes out. I am going to take the truck to Dodge first thing in the morning and let them think on it (I still have my 100,000 Warranty). I just pulled a trailer the other day and I didn't have any problems. The fuel Filter is new I changed it out last week and I noticed at the bottom of the separator there was some small pieces of metal in it. ???
Old 11-09-2003, 10:55 PM
Marine's Avatar
Might be the lift pump if metal at bottom of canister. My lift pump went out and I did not find any metal in the canister.
Mike
Old 11-09-2003, 11:01 PM
DODGE4X4's Avatar
It isn't my overflow valve it is good and there isn't any smoke.
Old 11-09-2003, 11:08 PM
Marine's Avatar
After reading your first post for the 4th time, it could be a ground problem between the truck and trailer. Does it do the same thing with other trailers?
Mike
Old 11-09-2003, 11:10 PM
DODGE4X4's Avatar
How would the ground of the trailer cause my truck to run bad ?? How did your truck act when your lift pump went out?
Old 11-10-2003, 10:13 AM
DODGE4X4's Avatar
Well the Lift Pump is working right it was a speed sensor on the tranny :
Old 11-10-2003, 11:26 AM
Administrator / Scooter Bum
Shovelhead's Avatar
Thanks for posting the fix.
We see many, many posts reporting troubles and members offering several suggestions as to the fault.
It always helps to see what actually solved the problem.
Ed
Quick Reply: Fuel Pressure Gauge
