Fuel Pressure Gauge
Fuel Pressure Gauge
Okay, made my mind up to install a fuel pressure gauge but trying to decide on a mechanical or digital. I have picked out the spot to install it (saw a pic that I can't find anymore of a gauge that was installed in place of the cigarette lighter plug on the dash, it looked sweet).
Any suggestions on make and 15 or 30 psi? I have an 03.
Stock fuel pressure is around 8 psi with a clean filter so a 15 will do but if you have or are looking at a aftermarket fuel pump it willl have a higher psi so a 30 would be better. Mechanical is better in my opinion but thats just me. Hope you make a decision your happy with.
i run Autometer Cobalt gauges, i usually run mechanical gauges but for the fuel pressure i go with an electric operated fuel pressure gauge. when u run the mechanical fuel pressure gauge u should also run a isolator valve which keeps the fuel from coming in the cab.the isolater valve is kinda awkward and is not a clean look, but that is me. hope that helps you
I just installed isspro ev2 gauges this weekend. They are all electric and I couldn't be happier. Mine is mounted right on CP3 and I'm not the least bit worried about vibration killing it.
Here's the backside of the panel. You can see I got too close to the vent. I have the Isspro gauge and it's hard to get the connector on if it's this close. Still turned out looking good though.
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
