Fuel Pressure Gauge
Old 08-27-2008, 09:16 PM
Ram_SRT-10's Avatar
Fuel Pressure Gauge
i am lookin to get a fuel pressure gauge what would i need it to go to 0-30 or 0-15 and what should my number look like once i get the gauge
Old 08-27-2008, 09:28 PM
AggieJustin's Avatar
I'd recommend 0-30. If you get a 0-15, your ideal pressure would be in the top 1/3 of the gauge. Or you may peg it at 15psi, depending on your fuel supply.
Plus, gauges are supposed to be more reliable in the middle of their range, so 0-30 puts you right in the sweet spot.
I used to run a 0-15, then switched when I found my gauge sitting past 15 most of the time.
Old 08-28-2008, 12:51 AM
nmen's Avatar
Stock lp only: 0-15
After market supply pumps: 0-30
Old 08-28-2008, 03:29 PM
Actually, I still have a stock LP. But I'm running larger lines and AN fittings and I idle at 16-17.
Old 08-29-2008, 02:20 PM
nmen's Avatar
You've pretty much defined it then. Go with 0-30.
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: Fuel Pressure Gauge
