fuel pressure gauge??
Old 07-23-2008, 06:38 AM
ct2500's Avatar
hey guys, on my home from work and noticed fuel psi gauge was not fluxuating like it normaly does it was pined on 19psi. so i shut truck off bumed the key switch pump came on and ran.so when i got home i checked all of my connections and they are all good didnt have test light to check power though.so this morring on my way to work i look at it and it is working.has any body experinced something like this before??
Old 07-23-2008, 08:06 AM
high bid's Avatar
If you have an isolator installed, check it...from what I've read, they don't last long.
Old 07-23-2008, 03:42 PM
ct2500's Avatar
its all electirc not mech
Old 07-23-2008, 08:17 PM
carl48's Avatar
most of the sending units are failing due to the vibration we use a 6'oil sending unit kit and a snubber between the pump and sensor to eliminate failures
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: fuel pressure gauge??
