Fuel pressure gauge fitting
Old 08-31-2007, 01:19 AM
Sasqoutch's Avatar
Im fixing to order the walbro pump kit, 2 micron inline filter kit, big-line kit from Glacier and Auto-meter ultra light boost, egt, and fuel pressure kit from xtreamdiesel. The fuel gauge is electric and comes with a 1/8" NPT sender fitting. My question is that when i install all this and remove the stock lift pump from the engin are there any other fittings im goin to need to buy in order to go from the walbro (mounted on the frame) to the stock filter bowl? Is there a place to install the gauge fitting on the bowl or should i just order a T and place it between the filter housing and cp3? What do you guys think.
Old 08-31-2007, 01:32 AM
Sasqoutch's Avatar
http://www.glacierdieselpower.com/pr...?pf_id=03045FA
This piece comes with the kit but does it install after i remove the stock lp?
Old 08-31-2007, 03:37 AM
blcoonrod's Avatar
That piece is what replaces your stock lift pump. I just ordered that piece from them. I am building my own kit. You could use the extra port in it for your FP sender. But if I where you I would put your sender in line after all the filters. If not you will read more pressure than you are getting at the CP3. Glacier offers a T that is 3/8" on 2 sides and 1/8" NPT for your FP sender in the middle. If I am not mistaking, I think it comes with the big line kit. If not I believe its only like $10 from them.
Old 08-31-2007, 06:50 PM
Sasqoutch's Avatar
Ok thanx for the help, thats what i needed to know! Brian
rock crawler
21
12-23-2008 11:20 PM
Big Smoky
01-16-2008 09:22 PM
trik396
03-09-2006 04:40 PM
shoe
03-28-2005 03:14 PM
CTDHokie
07-22-2004 05:24 PM
Quick Reply: Fuel pressure gauge fitting
