Fuel pressure gauge bouncing?
Old 03-14-2007, 02:56 PM
sleepr tsi's Avatar
My truck came with a mechanical FP gauge (0-100 PSI) that was disconnected when I bought it. The guy said it was because the noise drove him up the wall. I hooiked it back up today while poking around, and it bounces whildly (almost to each injector firing) from 5-40 psi, I can't really tell it moves so much. I spliced it in between the lift and injection pump.
It's not a water filled gauge, did I mount it in the wrong place or is it the gauge?
Old 03-14-2007, 03:45 PM
clutch1's Avatar
do you have a needle valve on the end
Old 03-14-2007, 03:55 PM
P.J
P.J's Avatar
Without a needle valve or "snubber" of some sort you are likely to see movement (and possible, eventual gauge damage).
Old 03-14-2007, 04:39 PM
sleepr tsi's Avatar
Probably not. Can I just order onr from summit?
Old 03-14-2007, 06:07 PM
clutch1's Avatar
1/8'' needle valve - $2.50 from the hardware store
Old 03-14-2007, 06:17 PM
P.J
P.J's Avatar
Your local NAPA, about $6.00, part#WH6820
Old 03-14-2007, 06:56 PM
infidel's Avatar
Run it with the needle valve barely cracked open.
Needle valve installed at head of line to the gauge
Old 03-14-2007, 10:02 PM
sleepr tsi's Avatar
Thanks, guys. I'll be swapping one in tommorow.
Old 03-15-2007, 09:40 AM
sleepr tsi's Avatar
At the risk of sounding dum, I was unable to find a needle valve. I tried napa first: no listing for that number.
I checked home depot and they didn't have any. Also went to advane. Any suggestions?
Old 03-15-2007, 10:17 AM
infidel's Avatar
This is where I get them
http://www.grainger.com/Grainger/wwg...mId=1612835462
Old 03-15-2007, 10:26 AM
P.J
P.J's Avatar
Huh. We have two NAPA's here, both of them pulled the part right away for me.
I sold a few fancy ones here a while back, had a **** on top instead of the bar, and a lock (stop) nut too.
I don't think I have any others, but I'll check.
Old 03-15-2007, 10:50 AM
sleepr tsi's Avatar
I checked the part number on napa's website and it came back empty
http://www.napaonline.com/MasterPage...PartNum=WH6820
I'll call again to confirm....
Well, asking by part number and not needle valve, they can get it. However, they don't have one at any of the local branches, so they'd have to order it. They can't order one, though. Only 5@7.25 each.
Old 03-15-2007, 10:53 AM
Dr. Evil's Avatar
Another option is a pressure snubber....although its more expensive.
Bottom of the page:
http://www.dieselmanor.com/isspro/isspro_accy.asp
Old 03-15-2007, 11:00 AM
sleepr tsi's Avatar
Hmm, cheaper then buying 5
Old 03-15-2007, 11:04 AM
Dr. Evil's Avatar
Quick Reply: Fuel pressure gauge bouncing?
