fuel pressure adapter
Old 06-04-2005, 04:32 PM
mojave_ron's Avatar
new to the board im planning on purchasing a fass system and looking for a inline push lock fuel pressure adapter to install close to injection pump but not sure what will work with the fuel line that comes with the fass;any help would sure be appreciated
Old 06-04-2005, 08:12 PM
HOHN's Avatar
I'm not sure of the diameter hose that the FASS uses, but getting a FP guage in shouldn't be too hard.
Have you considered Scotty's Smart Fuel system? I think it would work with your FASS 2 pump-- it may require some adaptation. Scotty's setup is just 1/2" hose, so adapting is easy.
The heart of his system is the fittings-- THOSE are the biggest restriction in the stock setup, and these are the highlights of the new system. They fix the biggest problem with the stock setup.
www.scottyairsystems.com
jlh
Old 06-04-2005, 08:42 PM
mojave_ron's Avatar
I have considered going that route but decided to go with that Fass System with filters. I was going to hook up fuel line directly to injector pump. That would elimante the stock fuel filter. I want to tap into the fuel line 6 to 8 inches before the injection pump. I found 6 an fittings but I am not sure they will work with the fuel line supplied with the Fass System.
Old 06-06-2005, 05:58 PM
farmer dave's Avatar
The fuel line is 3/8". I was also having problems hooking up the fuel pressure line after the install of the FASS. I ordered a kit from the person that I got the gauges from. I is just a T the is spliced into the line with an adaptor on it.
genesis
11-11-2010 11:28 AM
2500
10-17-2008 12:23 PM
deruwe2002
04-10-2007 12:34 AM
ladysmithmike
07-06-2006 09:56 AM
Scotty
12-20-2004 11:32 PM
Quick Reply: fuel pressure adapter
