fuel press help
Old 01-20-2008, 02:44 PM
bpollard1248's Avatar
fuel press help
hey guys i just installed an isspro fp gauge from vulcan and followed the instructions and i am getting only 9psi at idle and drops to 2psi at WOT BUT i had it checked 2 weeks ago with a gauge and it was 12idle and 8 WOT the only thing i can think is at the gauge the little compression fitting thing {looks like a metal sleeve that goes b/t the two ends} is pinching the line at the gauge. just about half of the plastic line is pinched...maybe that is my problem but please help thanks!!!!
Old 01-20-2008, 02:55 PM
bullboy85's Avatar
humm, even pinched at idle it should level off to the corect pressure. im guessing this is post fillter, if you got a bad tank of diesel then that could of cloged up your fillter... thats my best guess right now.
Old 01-20-2008, 05:25 PM
well i put it at the schrader valve on the injection pump and i even filled it up with new diesel so i think im gunna try a new carter lift pump my buddy works at a truck shop and can get it for $47.00 so its worth a try then i will be able to elimanate that. but thanks for all the help
XChris1632X
02-24-2008 12:43 PM
Gman_dodge
09-21-2007 04:33 AM
j
05-16-2007 08:11 PM
Evildiesel
06-30-2005 04:27 PM
Cooter02
01-14-2005 10:54 AM
Quick Reply: fuel press help
