Fuel Press. Gauge
Fuel Press. Gauge
Where should the fitting be installed for mech. fuel press. gauge coming from the tank?? (close to the cp3??) What should the press. start out at?? Same for rail press for starting out?? I'm trying to get better equipped and more knowledge.
I tapped into my big line just before the CP3.( push lock Tee fitting from Vulcan performance). Its after filter so hopefully the gauge will let me know when the filter needs changing. At idle I see 19psi and WOT drops down to 13or14psi. Not sure on RP yet... Alot of guys seem to be having trouble with their qzilla RPgauge, so I'm going to save a few more clams and get the DiCipricol.
FWIW, when I had mine installed, its using a banjo bolt in the filter housing with a hose to the isolator.
Being stock engine, it shows 9 at idle and at WOT it drops to 6.
j
05-16-2007 08:11 PM
