fuel lift pump question
Old 07-28-2006, 10:06 PM
ummmmmm......'s Avatar
hi, i'm not that familiar with my dodge yet. i've been looking in my haynes manual for the location of the fuel lift pump and how to properly replace it. any websites i can go to get a step by step.
thanks
Old 07-28-2006, 10:21 PM
Begle1's Avatar
Howdy!
It would help if you told us what year of truck you had; I don't know about later models, but on the first generations (1989-1993) the lift pumps were installed on the driver's side of the engine block. They're mechanical beasties and virtually bulletproof. (Somewhere along the line they went to electrical pumps that grenaded every few thousand miles. )
Anyways, here is a link explaining how to install a piston lift pump into a first gen. The piston pump is a more expensive, better flowing pump, but the steps are more or less the same if you just want to install another stock pump.
https://www.dieseltruckresource.com/...ad.php?t=93722
(Thank you BC847 for the excellent write-up. )
Of course, if you're truck has an electric pump, I don't think that helps any.
Old 07-28-2006, 10:35 PM
awesome. i have a 1996 dodge ram 2500 cummins turbo xtra cab. thanks very much for the help. is the 1996 second generation?
Old 07-28-2006, 10:42 PM
Begle1's Avatar
Yes, the 1996 is a second generation.
And I think that the second gens had very similar style mechanical lift pumps, and that the electric pumps came around with the third gens in 1998.5. Don't quote me on that one, however.
Old 07-28-2006, 11:28 PM
thank you very much.
Old 07-29-2006, 07:45 PM
TxDiesel007's Avatar
Uummmmmm..
Hopefully this will help you out..
This is borrowed from Infidel (Bill's) gallery. The lift pump is the little thing right next to the fuel heater housing below the Fuel filter housing. It does have a little plunger so it should be easy to see...
Hope this helps
Rick
Txwelder
12-18-2023 02:35 PM
chris4122374
12-16-2007 05:55 AM
ScreaminEagle
10-31-2007 03:31 PM
Gene
09-10-2005 09:32 PM
Txwelder
05-19-2005 06:10 PM
Quick Reply: fuel lift pump question
