fuel heater
Old 01-02-2010, 10:32 PM
levans's Avatar
fuel heater
93 dodge fuel heater is leaking how is the easiest way to get it off and should I put it back on?
Old 01-03-2010, 12:27 PM
1st Generation Admin
BC847's Avatar
Moved to the 1st gen forum board for better response/reply's.
- Remove the fuel filter and take a big, wide blade something; screwdriver, chisel, etc. and unscrew the threaded pipe that the filter screws onto.
That will let the fuel heater fall away from the head. Time and use of the engine has had the rubber "Square-Cut" O-ring degrade (a common thing with the older trucks).
Replace that square-cut O-ring and you'll be good to go.
Be sure to wipe clean the surface of the head as well (see the footprint of the square-cut O-ring).
Old 01-05-2010, 04:46 AM
91.5CTDBanks's Avatar
That is a nice write up Dave, I need to do it too.
Old 01-12-2010, 05:26 AM
USMC1349's Avatar
Is this the same procedure to remove th fuel heater on the '97 with the 5.9 12v? I have all the parts, new screen w/o-ring, new heater w/o-ring and wirng harness for the heater.(had a melt down). Have tried to remove the heater but not sure. I have the service manual but do not see anything about removing the heater. Any recommendations on this?
Old 01-12-2010, 05:42 AM
ofcmarc's Avatar
Should be nearly identical procedure. I know that with a bit of modding, a 2nd gen heater will fit a 1st gen.remove the spud and the heater should come right off.
Old 01-19-2010, 04:29 AM
USMC1349's Avatar
The threaded insert on that holds my fuel heater on used a 5/16 allen wrench to remove. Counter clockwise to loosen. Thanks again for the pictures on this. Really helped out.
rjm022
12-11-2019 09:17 PM
Ramrod90
02-03-2009 07:39 AM
modiesel
03-07-2008 10:44 AM
taildragger
12-04-2006 10:00 AM
Reelay
12-01-2005 06:14 PM
Quick Reply: fuel heater
