Fuel Filters
Old 09-29-2005, 01:55 PM
Motorpool's Avatar
Fuel Filters
Okay Boyz, I have a problem I need one or more of you to straighten me out on. My 1999 Dodge will not run right on the aux tank. Here is what I found this morning. I have the switch on the original tank and I get under the truck with engine running and I see some bubbles forming around the inlet of the clear housing inline filter, not many, just a few. Then I switch the toggle to the aux tank while the engine is still running and crawl under the truck and look at the inline filter for the aux tank and the bubbles are ten or more times more and now they are real small bubbles. Is this air sucking in somplace between the tank and the filter or is it water in the tank causing the pumping to make it look like air bubbles???? Thanks, Sonny
Old 09-29-2005, 04:24 PM
phox_mulder's Avatar
Could be either.
A little water contamination will look like air bubbles, best way is to capture some of it in a clear jar and let it sit.
If it is wter, it will go to the bottom of the jar, air will go to the top.
phox
DodgeCowboy
07-23-2008 10:12 PM
bcfitzsimons
06-26-2008 12:17 PM
staarma
28
05-01-2008 11:10 AM
fitzydog
10-12-2007 10:23 AM
kelley15
08-20-2007 04:52 PM
Quick Reply: Fuel Filters
