Fuel Filter O-Ring?
Old 02-03-2010, 12:34 PM
kyman's Avatar
Fuel Filter O-Ring?
I just cahnged my fuel filter for the first time since I have owned it (1yr 4k miles). There was no O-ring anywhere. I put the new one on the lip of the filter canister so the lid would seal against it when tightened. I guess this is correct? Thanks!
Old 02-03-2010, 12:46 PM
ssandlin's Avatar
I can't confirm if the 04.5 is the same as my 06, but on mine, the o ring goes on the lid, not the canister itself.
Old 02-03-2010, 12:50 PM
troll3193's Avatar
I have owned a 04.5 and now an 06 and they are the same... the o-ring is installed on the lid, prior to screwing the lid into the body..
Bryan
Old 02-03-2010, 01:26 PM
kyman's Avatar
Guess I better take it back off and put it on the lid. Where does it goon the lid? Thanks!
Old 02-03-2010, 01:47 PM
SpeedyWS6's Avatar
Slide it over the threads until is sits on the lip of the lid.
diesel4play's Avatar
It leaks like crazy if it isn't on right, don't ask how I know.
Old 02-03-2010, 01:50 PM
kyman's Avatar
LOL! Thanks guys. That's why I am here so you can teach the slow guy how to do stuff. Wonder how it worked w/o one on it?
Old 02-03-2010, 02:04 PM
CamperAndy's Avatar
Look in the filter bowl when you open it back up. It can stick to the canister and fall in once the lid is off.
Old 02-03-2010, 05:45 PM
Dodgezilla's Avatar
I cannot believe it would not have leaked if there was not one on there. I would contend that it IS there somewhere. It may have just fallen off from being stretched out.
Yes, roll it on to the lid, over the threads, and smear some diesel on it before you put it back on. Kind of like you do with an oil filter....
Old 02-03-2010, 11:57 PM
kyman's Avatar
It was hardened onto the lid, I found it. I don't think it was ever changed before. I did the oil change ( nasty stuff for only 4500 miles) put a new cold air kit on, and installed my SuperChips programmer on tow/haul. The trailer is hooked up right now, so I will get to give it a good test drive during a 6 hour round trip. Thanks guys!
wheelieking71
03-08-2011 03:58 PM
98.5POS
37
01-26-2007 08:26 AM
HaulinBut
05-12-2006 03:06 PM
midwestdually
01-07-2006 03:15 PM
StrokeThis2500
12-31-2005 05:19 PM
Quick Reply: Fuel Filter O-Ring?
