fuel filter change, and now won't idle well or keep prime long
My brother changed out my fuel filter, which it needed. But now it won't idle well. It idles better after we bleed the filter, the IP, and the lines at the injectors. But it still loses prime after a couple hours.
Should we suspect the lift pump? Brother says it was starting to run poorly, which is why he suspected the fuel filter in the first place.
Seems something always go wrong on the truck when my brother borrows it, of course.
Assuming the lift pump is the culprit, is it best to replace or upgrade?
I'd check the fuel filter first. I needed one quick a few months back and could only get a cheap one from auto zone, one of the o-rings (the small one) was defective and had a split in it after a week, had similar symptoms to yours. If you can, check the lines by pressurizing the fuel tank with compressed air, only a few pounds should show you any leaks.
the.hogman
12-07-2011 08:49 AM
dieselfuelonly
18
09-23-2010 09:27 PM
MAC702
02-22-2010 08:56 PM
westcoaster
02-26-2008 10:41 AM
Idaho Guy
20
02-15-2007 03:37 PM
