View Full Version : Fuel Economy
batexp
09-09-2005, 02:11 PM
OK.. I've poked around here and figured to find this question asked to death, but can't find it. On my '05 what kind of fuel economy should I be getting and what is the best it will ever be. I've had it for 10 months. It now has 14k miles. I've changed the oil 3 times, replaced the air filter at 10k. The best it will get is 14 city and 17 hwy. I am tired of these jerks with fords and chevys braggin about their diesels getting 18 city and 22 hwy and laughing when I tell them what mine gets.
Stats: '05, 2500, 4wd, automatic,stock Cummins, stock tires, stock everything.
Quiestions:
1. Is this....
normal break-in.
just bad luck.
Cause it's a 4wd
cause Fords and Chevys are better than Dodge [yuk]
2. Should I...
Blow my 100k warranty and start adding preformance stuff
Set it a-blaze and collect the insurance
Trade it in for a Dura-min or a Power-Anurisim [dummy]
Just deal with it cause it's better than I was gettin with my old gas truck.
3. Do preformance chips really help fuel economy
Note: sorry I posted this in the wrong spot, thought I was still in the general area. How do I move this?
widelod
09-09-2005, 02:21 PM
I get 17 around town in mine, with 11000 miles in 5 months....it may just need a little more time for break in too.....
As far as your cheby and furd friends, you can take great pride in having the same truck 5 years from now when they are having to buy new trucks from where their engines have given out.
59022
09-09-2005, 02:58 PM
I get 17 highway and 13 towing with sig vehicle. With the Unimog and the Mercedes diesel I get 10.
RAM2940
09-09-2005, 07:07 PM
Do you excellerate real hard from a stop, and how fast do you drive on the highway. These are some big factors on fuel mileage. Everyone drives differant. A boost guage will really tell how hard you are driving.
Hayseed
09-09-2005, 07:11 PM
Have you really worked it yet? If not try pullin somethin really heavy at highway speed for a couple hundred miles. It worked for my dad's '05 w/ 1500 miles. Now he gets 19-20 highway!!
mtedwards
09-10-2005, 01:07 PM
I just bought the truck vehicle in my sig two weeks ago. I haven't towed anything with it yet, so I only have unloaded fuel numbers.
I do 75% interstate driving at about 68mph. I've been getting 18.8 calculated and 19.3 on the OHD. The truck has 1400 miles on it now.
My friends identical truck is getting about 13 on the ohd and 13 calculated. The only difference is he has the factory bfg's and I have the michelins.
I typically drive pretty easy accelerating from a stop light. My average mileage on the OHD usually goes up a couple tenths in city driving, but drops back down on the interstate.
MikeyB
09-10-2005, 06:46 PM
The Furd and Cheby guys are lying to you.
MikeyB
batexp
09-12-2005, 10:50 AM
I drive pretty conservetivly around town. Highway speed depends on my mood. 80mph when I need to get there fast [whistle] 70mph if I'm feeling socially responsible :rolleyes: and 65 if I'm trying to get the best fuel milage. About 15% of the miles were towing a 5000 lb trailer.
How critical are fuel filter replacements?
How often should I be doing filter changes?
What kind of milage are you folks getting?
Will the proformance "chips" help?
drew03
09-12-2005, 11:04 AM
i change oil, oil filter, and fuel filter every 5-6000 miles or so.
batexp
09-12-2005, 11:14 AM
Is it that critical to change your filter that often. I am new to the world of diesel engines so it suprises me that you change yours that often.
batexp
09-12-2005, 11:36 AM
Just testing my signature.
theextricator
09-12-2005, 04:36 PM
I just hit the 4200 mile mark. I am getting 16mpg around town, 13 -14mpg towing 6500lbs, and 19 -20 mpg empty on the highway at 65mph.
Boredexec
09-12-2005, 06:10 PM
You should try this -
I was getting 11.5 city (So Cal) and 16 highway at 70 MPH.
I put in the Quadzilla Xillaraider race chip (3 HP settings) with the middle HP setting (100 HP gain) and a cold air intake. AirRaid or K&N or any other, they are mostly alike.
I now get 15.8 city driving and 24.9 highway at 72 MPH.
I got as high as 31.8 MPG in Oregon going 60 MPH (55 MPH zones on rural highways there)
Another thing you can do is get Gear Vendors. It adds another overdrive (if I understand it correctly) and should get even better.
I am putting on a 5 inch exhaust system that I just ordered and that should gain even more MPG.
Just with the chip and intake I am getting over 700 miles per stocker tank when the dummy fuel light comes on with a loaded bed but no trailer. approx #500 lbs in bed.
Hope this helps.
John Faughn
09-12-2005, 07:11 PM
Do you know what gear ratio you have ? it seems like you've got most things covered but it difficult to over come 4.10s when what you want is 3.55s
RATTLINRAM
09-12-2005, 09:18 PM
Hope this helps.
Not meaning to start any arguments,,,, But you do know that unless you are calculating your mileage by hand,,,,, any Fueling Boxes like the Quadzilla, EZ, Edge Comp, TST, Bluechip, etc. are going to throw your overhead mileage computer WAY OFF. My hand calculations were close to being right on the money with the overhead when the truck was stock. With just the DD2 injectors and an EZ,,,,,,,, the overhead says I'm getting 8-9mpg better than what I'm actually getting when calculated by hand. (I get a kick out of pointing to it whenever a Ford or GM guy asks me about what kind of mileage I'm getting!) [laugh] I'm still getting around 20-21mpg running empty as long as I drive sensibly,,,,,,,,,,,,,,, But where's the fun in that? [laugh]
BoostdCTD
09-13-2005, 03:34 AM
My worst tank so far has been about 20mpg, my best was almost 24mpg (I drive about 50% city, 50% country roads). I've since advanced the timing, added a tonneau cover, lashed the valves, and put in a hotter thermostat so I'd like to think I can tweak that number up a little higher especially once I get a better air filter.
Now that you're thinking BS how can I get that mileage... well it is all about how hard you drive it. For instance I'm trying to get my waterless coolant thing all finished off, last thing I had to do is get the water that was in the block boiled out. Well I stuck a piece of cardboard in front of the radiator and drove to work today, since I never really accelerated very hard even though it was 90*F outside my motor never made it much over 200*F.
Chrisreyn
09-13-2005, 04:13 AM
I'm up there with Boost.. I am averaging about 22mpg, mixed city/highway. I have no mods to the engine except for the BHAF/ Old Smokey Mount.
Pulling a 28ft gooseneck with 3 1200# Quarter horses, I get about 18-20.
I keep my foot outof it as much as possible, try to stay in the 1800-2000 rpm area if I can, and make long stops and long take-offs......I drive like a Grandma according to my daughters, but it pays off.... :)
batexp
09-13-2005, 12:29 PM
So many choices.
Just ordered the "Edge" comp. Got to try something. My last tow (actual calculations) netted 10.5 mpg on a 600mi round trip. Sucks pretty bad IMO.
Plan to change the fuel filter today. Ya'll still have not made any statement as to the scheduling of fuel filter replacement or if it will have any impact on economy.
May be that I am freeking out about nothing. The crappy milage that I am getting may just be from lack of break-in. I have heard that 40k is a good break-in period for this engine. Also heard that 15k is a normal break-in. Too many opinions not enough resource for facts.
In some cases you guys give me hope that mine will get better. My opinion remains that this is the toughest looking truck on the road and the CTD is one pullin' mutha.
BTW... what the heck is waterless coolant and how does it work?
drew03
09-13-2005, 04:38 PM
i would hate to be stranded or have to replace an injector pump because of a 11$ filter :rolleyes:
The filter is solid black when i remove it after 5k
BoostdCTD
09-14-2005, 12:10 AM
Sounds like you have an algae problem, try some biocide.
Waterless coolant (http://www.evanscooling.com/index2.html) is just that, imagine if you weren't held back by having water in there. The boiling point of the system could be much higher. Well with this waterless coolant it'll boil at 375*F @ 0psig. No more cavitation, corrosion, electrolytes, silicates, pressure, or worries about boiling the system over.
kg4muc
09-17-2005, 10:13 AM
Quiestions:
1. Is this....
normal break-in.
just bad luck.
Cause it's a 4wd
2. Should I...
I would allow more breakin time. Mine didnt really begin to get the mileage it's getting now (17-21 mpg) until it hit near the 30K mark.
As for the DuraMaxies and all Just remember you WILL be running in 5 years they might not(especially the Duramaxes I make my living working on them)
Wayne
BoostdCTD
09-17-2005, 02:36 PM
No wonder you bought a Dodge. ;)
kg4muc
09-17-2005, 04:13 PM
Exactly :)
vBulletin® v3.6.7, Copyright ©2000-2009, Jelsoft Enterprises Ltd.
