front yoke
Old 11-05-2010, 04:50 PM
OVERBOOST's Avatar
front yoke
Does anyone know where I can get a front (dana60) yoke for my 1992 w250. I went to auto parts store in need of u joint and bought one and installed it with new straps and the joint slides side to side. The ears are missing off of the yoke that hold u joint in center. I thought the straps would pull down tight enough to hold it but it didnt. Oreily A/P cant find the correct yoke any help would be great.
Old 11-05-2010, 06:43 PM
schamran's Avatar
Northern Driveline would have it, or northwest fab works. I have had good experiences with Northern Driveline, but I haven't ordered much from them.
Old 11-05-2010, 07:09 PM
366 Spring Chicken
Richie O's Avatar
You may end up getting the bigger style that the 93's have and get a u joint thats small on the driveshaft end and bigger for the axle side. I got mine from 4 wheel parts. com and at that time its all that DANA offered.
Old 11-05-2010, 09:19 PM
OVERBOOST's Avatar
Red face
Is there a part number that I can get off of it to order the correct one? Or will they know which one it will take by ordering it for 1992 with dana 60. Also thanks for you help fellas.
Old 11-06-2010, 05:54 AM
Douglas2's Avatar
FIgure out what U-joint it is. Google will take you to many sites and all you'll need is to measure end-of-cap to end-of-cap and its diameter( of the cap that is). I got my rear yoke from Riverside Gear. It was a forged one v. cast at just a slight premium in cost. It took the u-bolts too( not a fan of the strap ).
cheers,
Douglas
Old 11-06-2010, 10:22 PM
schamran's Avatar
Sorry My yoke came from Northern Drivetrain, not northern driveline. I ended up getting a conversion u-joint, it think it was a 1350 on the axle, and a 1310 on the shaft. If you were picky you could probably get a new end for your driveshaft to run the 1350 joint. I did when I ordered a new shaft.
Old 11-07-2010, 10:06 AM
HARDTIMES's Avatar
Do the dana 70 and dana 60 have the same size pinion where the yoke slides on? I once thought I heard you could put a 1410 dana 70 yoke on the 60?
Old 11-07-2010, 12:36 PM
PapeCAT's Avatar
60 and 70 are the same so you can put the 1410 on there yes.
Also, my front yokes are all the mopar type with no ears but the correct u joints have a clip on the caps that keep them centered... No Yoke ears here either.
csramsey640
06-04-2014 10:31 PM
woodrat
02-18-2008 11:50 PM
dieselcarpenter
09-18-2007 06:01 PM
Common
03-25-2007 06:16 PM
andyr354
07-25-2006 11:27 AM
Quick Reply: front yoke
