Front Universal
Old 06-14-2008, 08:09 PM
Dynocon's Avatar
Front Universal
With 78K I think I heard the from U joint creak a little. I have read that the NAPA HD are pretty good. How hard are they to change? Any tips?
Old 06-14-2008, 08:58 PM
mikmaze's Avatar
are you talking the u joint on the axle or the front drive shaft ??????? axle is a pita thats why i let the dealer do mine for free o yeah, btw, had the front driveshaft replaced that way too !
Old 06-15-2008, 01:33 PM
Dynocon's Avatar
Not sure. I put it 4 wheel and it clumked on the front left, I think. That is the only time it did it. I assume it is the U joint.
Old 07-31-2008, 05:01 PM
Dynocon's Avatar
It is the u joint on the front drivers wheel. How hard is it to change?
Old 07-31-2008, 07:39 PM
JP-4.5's Avatar
I just had mine changed. I was going to do them myself but could not get the hubs off. A local diesel shop did mine. They had to cut the stock hubs out with a torch!! Luckily I had decided to do the free spin hubs before attempting this. I would have some hubs on hand if you are going to attempt this. Also be sure that ball joints and tie rod ends do not need replacement. Now is the time to do them if needed.
Good Luck..
Old 08-01-2008, 09:34 PM
booman70's Avatar
Did both of mine @ about 40k dont use a puller on the hub press it out from behind using the power steering. The first one was a real pita till I figured it out the second one was much easier.
BC847
07-30-2013 08:48 PM
KWKING
11-29-2012 09:42 PM
schoust
11-27-2009 09:30 PM
ollie32
08-08-2007 11:05 PM
Nav
07-21-2006 09:19 AM
Quick Reply: Front Universal
